Introduction: Helping Hands With Led Tester.
Very useful when working with microchips and handling small parts
Has a white led to light up a specific area or there were light is needed.
Here is all you will need:
- Some malleable wire
- 1 led (colour is optional)
- 6 alligator clips
- 2 AAA battery holder
- Soldering iron & solder
- Piece of wood
- Glue or epoxy
- Bread board (the +- part)
- Shrink tubing (optional)
- Switch
- 6 alligator clips
- Piece of wood
- Glue or epoxy
- Switch
Step 1: How to Make an Arm.
To make this arm out of you materials you will need:
- Some wire that can bend into shape
- 6 alligator clips
Step 1
Strip the end of the wire (about 1 cm will do)
Step 2
Bend the striped wire in the middle and back onto it self
Step 3
Put the wire in the slot of the alligator clips, which looks like a U, and bend it around the striped end.
Step 4
Solder it in place for added strength and put on some shrink tubing.
Step 5
Make 6 of these.
- 6 alligator clips
Step 1
Step 2
Step 3
Step 4
Step 5
Make 6 of these.
Step 2: Now for the Base
The base I made out of pure wood (it is stronger and is heavier). I drilled 6 holes for the arms and 3 holes for the wiring and also1 hole for the light rod.
Here is what you need for this part:
- piece of wood
- glue or epoxy
- bread board (the +- part)
- switch
Part 1
First pencil out the spots were you are going to put the holes then drill all the holes you need.
Part 2
Take of the protective film and place it on the board.
Part 3
Now solder the switch to two wires and put shrink tubing around the soldered parts.
Part 4
Put the battery holder with double sided tape on too the board and guide the wires through the whole to the bottom.
- piece of wood
- glue or epoxy
- switch
Part 1
Part 2
Part 3
Part 4
Step 3: Building the Light Rod.
The light rod is a led on a malleable wire. It is very useful for when soldering microchips and you need to see which component is on the other side you do not need to flip over the microchip.
Here are the materials needed for this step:
- some wire that can bend into shape
- soldering iron & solder
- shrink tubing (optional)
Follow the instructions on the pictures:
Step 4: Puting It All Together
Just glue the arms in to the holes and attach the wiring together and you are done.
Please give feedback this is my first Instructable. How can I improve?
