Introduction: Herbal Facial Serum
I made an herbally infused facial serum from homegrown flowers.
- A dehydrator (optional).
- A quart mason jar with lid.
- 1-2 bottles of jojoba oil or other cold-pressed carrier oil you choose.
- A bowl.
- A small funnel.
- A spoon.
- Therapeutic grade helichrysum italica essential oil.
- One amber 1oz dropper bottle.
- Fine mesh strainer.
- Fresh or dried Calendula and Chamomile flowers.
Step 1: Harvest Chamomile
Harvest Chamomile (Matricaria Retutica) and Calendula (Calendula Officinalis) flowers by picking mature open flowers and placing into a bowl. Note: If you are using purchased dried flowers skip to step 7.
Step 2: Prepare Your Dehydrator
Place a sheet of wax paper on your dehydrator sheet in preparation for the flowers. Be careful to use a piece of parchment paper that is the correct size for your sheet.
Step 3: Spread Flowers Onto Parchment Sheet
Spread the Chamomile and Calendula flowers evenly onto your prepared parchment paper sheet.
Step 4: Dehydrate
Place your dehydrator sheet with the flowers into your dehydrator, shut the door, set the temperature to 95 degrees Fahrenheit, and dehydrate for 3 days.
Step 5: Repeat Previous Steps
Repeat the previous steps until you have .7 ounces of dried flowers.
Step 6: Remove
Remove flowers and trays from the dehydrator.
Step 7: Weigh
Place dried flowers into the bowl (after taring) to reach the desired weight of .7oz.
Step 8: Add Your Oil
Pour cold-pressed jojoba oil into the bowl containing the .7 ounces of flowers until all of the flowers are well saturated, then cease. Note: I used jojoba oil because it is non-comedogenic (won't clog pores), you may use any cold-pressed carrier oil that you desire that works for your skin type.
Step 9: Macerate
Blend the flowers and oil in a blender for 10 seconds.
Step 10:
Pour your macerated herbal oil into a quart glass mason jar and then fasten the lid.
Step 11:
Mark the date on your calendar, so you can be sure to let the herbs steep for exactly 14 days.
Step 12: Cover
Cover your jar with an old sock. This is to block light from entering the serum and degrading the herbs.
Step 13: Infuse
Set your jar in a sunny location outside to infuse for 14 days.
Step 14: Strain
Strain oil into a bowl using a fine mesh strainer.
Step 15: Combine
Add 15 drops of therapeutic-grade Helichrysum Italicum essential oil into the strained oil.
Step 16: Bottle
Pour finished oil into a 1-ounce amber-colored dropper bottle using a small funnel.
Step 17: Enjoy
Use your sumptuous facial serum whenever you want to pamper yourself. Note: I use mine every day!
