Introduction: Hex Nut Necklace
A lot of hardware is way cuter than it is given credit for. Hex nuts, for example, are adorable!*
This is a super simple and quick necklace to make. And since it is fast, the variations you will inevitably think of while putting it together will be equally easy to try out (double or triple stands, shorten to a choker, try out different beads, create intricate pendants).
If you do play around with this idea, please post your finished work!
* If you agree, here are two other hexy Instructables you might enjoy:
https://www.instructables.com/id/Chocolate-Nut-Assortment/
https://www.instructables.com/id/Hex-Nut-Tree-Topper-and-Ornaments/
Step 1: Materials and Tools
Materials (18" necklace)
38 Small hex nuts, 1/4" in diameter
2 Standard sized hex nuts, 7/16" in diameter
39 Pieces jewelry wire, 1" long, 22 gauge
3 Cylinder hematite beads
1 Eye pin, 22 gauge
3 Headpins, 22 gauge
Tools
Wire Cutter
Round pliers
Metal file
Step 2: Form Chain
To make the chain
- Using the round pliers, fashion wires into 'S' shapes
- Attach a small hex nut to one end
- Bend the loop to close
- Repeat until you have 17 pieces
Attach all pieces together to form chain
Step 3: Make Clasp
To make the clasp
- Bend one eye pin (eye end) to create a hook
- Attach small hex nut to the other end of the pin
- Attach piece to one end of the chain
- Attach one of the larger hex nuts to the opposite end of the chain
- Just loop through hex nut to close necklace
- This also makes the clasp nearly indistinguishable from the rest of the chain
Step 4: Hex Nut and Bead Pendants
To make pendants
- Loop wire around two small and one large hex nut
- Bend ends into a small hooks
- String beads on to head pins
- Cut excess wire, leaving enough to make a loop attaching the bead to the hex nut
- Hang on chain and decide spacing
- Loop and close the hooks affixing them chain
