Introduction: Hexagon Snowflake Ornament
This snowflake ornament is simply but yet so pretty for a tree.
This is the stl download link.
Step 1: Circle
First make a circle in 03 inches.
Step 2: Slices
Then make two slices that are 30 degrees apart. By making them 30 degrees you have to use the dimension tool
Step 3: Mirror
Then on one slice make a design for the snowflake.Once you're done with that you have to use the mirror tool to mirror it to the other side.
Step 4: Circular Pattern
Then use the circular pattern tool and highlight the whole circle. Once you did that change 3x and to 6x and hit the check.
Step 5: Extrude
Then Once you are done with the sketch, use the extrude tool And extrude the snowflake. also put the depth to 0.125.
Step 6: Small Circle
Then make a circle near the edge using the circle tool that is 0.2 inches. And make it 0.3 inches away from the edge using the dimension tool.
Step 7: Extrude Circle
Then hit the check mark for the sketch in the used extrude tool and extrude the circle. When you are extruding the circle make sure it is on solid and remove, and instead of blind quick it and put through all.
Step 8: Print
Then you have to 3D print it.
