Introduction: Hexbug Spider Whisker Sensors/ My First Instructable
My youngest son has a bunch of these Hex bugs (and got a bunch more for Christmas) and gave me one that I had repaired a broken leg on several times. I found https://www.instructables.com/id/Arduino-Spider/ but there wasn't any code and I just got an Arduino Uno for Christmas but no Ultrasonic Sensor. I decided to make whisker sensors/switches for my hex bug.
Parts:
Arduino Uno
wire (to extend the motor wires)
guitar string (or suitable substitute that is springy)
2x 10k resistors
I clipped the leads off of a diode for the vertical post (improvise as needed)
soldiering iron
Parts:
Arduino Uno
2x 10k resistors
soldiering iron
Step 1: Motor Connections
https://www.instructables.com/id/Arduino-Spider/ is what I used as my reference. On my unit the black wires I used as ground, the white wires I used for the digital outputs. As Creagon did, I extended the wires from the motors. I taped the Uno and feeler board to the top of the hex bug. I found the "forward" motor is the one on the left while looking at the off/a/b switch. I removed the IR sensor and control board.
Step 2: CODE
//constants
const int ledPin = 13; //built in led
const int bumpLeft = 2; //bump switch left
const int bumpRight = 4; //right switch pin
const int servoFw = 10; //forward movement motor
const int servoTrn = 8; //turning motor
int pbLeft = 0; //var for right
int pbRight = 0; //var for left
void setup() {
pinMode (bumpLeft, INPUT);
pinMode (bumpRight, INPUT);
pinMode (ledPin, OUTPUT);
pinMode (servoFw, OUTPUT);
pinMode (servoTrn, OUTPUT);
void loop() {
forward(); //start forward
//test switch
pbLeft = digitalRead(bumpLeft);
pbRight = digitalRead(bumpRight);
//show LED indicator
showLED();
//if left hit
if (pbLeft == HIGH) {
reverse();
delay(500);
turnRight();
delay(1500);
//if right hit
if (pbRight == HIGH) {
reverse();
delay(500);
turnLeft();
delay(1500);
//Motion routines
void forward() {
digitalWrite (servoFw, HIGH);
digitalWrite (servoTrn, LOW);
void reverse() {
digitalWrite(servoFw, LOW);
digitalWrite (servoTrn, HIGH);
void turnRight() {
digitalWrite(servoTrn, HIGH);
void turnLeft() {
void showLED() {
//show led if bumper hit
if (pbRight == HIGH || pbLeft == HIGH) {
//turn led on
digitalWrite(ledPin, HIGH);
else {
//turn LED off
digitalWrite(ledPin, LOW);
void setup() {
void loop() {
//test switch
showLED();
//if left hit
reverse();
delay(500);
turnRight();
delay(1500);
//if right hit
reverse();
delay(500);
turnLeft();
delay(1500);
//Motion routines
void forward() {
void reverse() {
void turnRight() {
void turnLeft() {
void showLED() {
//turn led on
else {
//turn LED off
Step 3: Final Words
I will probably redue this "ible" but for now here it is, any ?'s I will try to answer.
