Introduction: Hidden Highlighter
About: I love messing around with random things and turning them into instructables
Ever wanted a simple place to hide your money Without Spending hundreds of dollars on safes and locks?
Well then this instructable is perfect for you!
You will need:
• Highlighter
• Long toothpick
• Plyers
• HotGlue gun
• Money
Step 1: Disassembly
Use the plyers to remove the tip and bottom of the highlighter, then insert the long Toothpick in the top to remove the ink. Set the tip, the cap, the ink, and the body aside.
Step 2: Prep for Money
Heat the glue gun, then insert the tip of the glue gun in the bottom till the little prongs are melted a bit, then unplug.
Step 3: Hiding
Roll the money super tight and insert it into the bottom, put the bottom back in the highlighter, than put on the tip and the cap.
Step 4: Enjoy!
I hope you found this instructable usefull, and as this is my first instructable, I would appreciate it if you could leave some feedback so that my next one is better!
