Introduction: Hidden Shelf
So....I needed (wanted) a place to stash some, Oh I don't know, just something.
Step 1: Location
Location, location, location. Aren't studs supposed to be 16" apart on center? Mine were a little closer. Hence the narrow shelf width. Lots of insulation. And spiders.
Step 2: Frame & Paint
Frame it up. Start with a backboard. Then sides. Then top and bottom. Pretty simple with a tape measure. Stucco it, sand, and paint. Use orange peel to match the surface.
Step 3: Shelves
Add a couple of shelves. I used a nail gun with a compressor. Hinge selection?? Had to go with hidden hinges. You can get this on amazon. Widely used in kitchen cabinets. I prefer the soft close.
Step 4: Supports
Chose a frame. Mine was a simple beach scene, but it had a weak frame. So I had to reinforce it with an extra piece of wood, glue, and clamps. Next, using a forstner bit to countersink a hole for the hidden hinges. Screw in place.
Step 5: Finish It
Finish it. Screw in lateral supports and hinges into studs. Adjust it with a phillips screwdriver. Now, what do you want to hide in the secret compartment?
