Introduction: Hide Your Money Easily
This is just like what Kactapuss made in his instructable but mine is a little different. Hope you enjoy the ible.
Step 1: Materials Needed
•One spray paint can (empty or full it doesn't
matter)
•One can opener
•Duct tape (any color I got camo)
•One thin cardboard target
•Glue (I used Elmer's glue)
Step 2: Empty the Spray Paint Can
Whether your spray paint can is empty or not, use the duct tape to hold the nozzle down and leave for 10-20 minutes (depending on how full the can is).
Step 3: Cut Off the Bottom
Now you're going to take your can opener and cut the very bottom off right above the lip. Be careful because there is a chance that a small amount I paint will still be in the can. Once you do that pack plenty of paper towels in the can and leave it for awhile so it can dry. You'll also want to take out the plastic straw in the middle and the metal ball.
Step 4: Use Your Thin Cardboard Target
Roll your target up to fit on the bottom lid. Now cut about half or less of the target off the top so it will fit comfortably and look normal once your finished. I used regular Elmer's school glue to glue the bottom lid to the target. Use duct tape to hold the target in a circle. Now put a thin line of glue down where the target will rest on the bottom lid. Once you do this, set a small weight on top of the target to put pressure on it. Now put a small line of glue where the target and bottom lid meet.
Step 5: Nearly Done!
Now once the glue is dry, test it by making sure the whole thing will fit. If it does, then you can put anything secret in it.
Step 6: Finished!
I use mine to keep my money in. Make sure you don't tell anyone about it unless they want one too. Then direct them to this ible! Don't leave your secret spray paint can in a spot where it doesn't belong. Put it with other spray paint cans so it looks normal.
