Introduction: High Voltage Power Supply
Hello
My name is Marc i'm fifthteen and i'm a French student.
today i'm going to show you step by step my construction of this high voltage power supply
by the way sorry for my bad English
Step 1: This Is a Valve or Vacuum Tube
I use it for many applycations
but i use this for generating x rays and convert AC to DC
Step 2: The Coil
we use a coil to incrase the frequency of the flyback output this coil provide to a old fluorecent tube multipier
Step 3: The Flybacks
i use two flybacks one with six turns on primary and one with eleven turns on pimary core
with six turns you have some high current arcs like MOT (microwave oven transformer)
and with eleven turns you have nice blue electric arcs like NST (neon sign transformer)
Step 4: The Ballast
We need power so I use a ballast
this can prduce high current output to 12V 60VA with high frequency
power in 220V or 120V AC
power out 11.6V or 12.3V
Step 5: LET'S GO !!!
Before we get started
don't forget SAFETY !
add a switch on the output of the ballast this is important to be safe
4 Comments
5 years ago
so you use the tube as a crude recrivier
okey i need to clear a few things up
This tube is not a rectivier and is not used to generate xrays
it is a beam power amplyfier that is used to drive flybacks
if you use it to drive a flyback your arc goes from what you have to around 10 cm
also if you want to generate x-rays take a PD500 and hook it up to 25kv+
then you have a crude x-ray source
Reply 5 years ago
ok thanks
i have a bt95 and i generate now x rays XD
Reply 5 years ago
a Tyratron cannot be used for xray generation
you need a vacuum diode (pd510 or something like that)
a tube with no gas in it most Tyratrons are filled with argon or merqury
5 years ago
Interesting. I have a bunch of old vacuum tubes that I inherited from my father in law. I might have to try this.
