Introduction: Highlighter Pen
Imagine someone asking you to barrow your pen but then you pull out a highlighter, well your in the right place.
You need a highlighter, tacky glue, scissors,
Step 1: Pen in Highlighter
First grab a highlighter and set it down.
Step 2: Step 2: Taking Off the Tip
Next you have to take the yellow tip off and throw it away. Then take off the bottom by using scissors on the white slits. Then pull down the scissors to take it off.
Step 3: Step 3: Pen
Take everything out once the bottom is off. Then take you pen and unscrew it so the inside come comes out. After put that pen part in the highlighter.
Step 4: Step 4: Tacky Glue
The bottom of the highlighter should still be off. Then pour your tacky glue into the highlighter to keep the pen in place. The bottom of the highlighter should still be off. Then pour your tacky glue into the highlighter to keep the pen in place. Then put the cap back on and let dry. Turn it upside down for 10 minutes them turn it back on its bottom for 4 hours. Your done!
