How to Spray Paint Your Jeep and Make an Assault Vehicle
Intro: How to Spray Paint Your Jeep and Make an Assault Vehicle
Ok since my jeep is a major beater and I take it offroading, what better way to paint a fading beaten up jeep than with spraypaint? I chose to paint it up like an Army assault vehicle and add some zombie stickers. So to start you need a vehicle you plan to paint. (I advise it to be something that you dont really care about getting beaten up) For me that would be my 1990 Jeep Cherokee that I drive offroad a lot. Heres a picture of what it should look like once it is done.
STEP 1: Find a Vehicle
Step one find a vehicle. You can use an existing vehicle or go buy one like me from craigslist for dirt cheap. :D Aw look at the lil jeep the day I bought it.
STEP 2: Supplies
Now drive to your nearest hardware store and buy the following:
-Spray paint (10 cans of Krylon Satin Italian Olive)
-220grit sandpaper
-a can of mineral spirits
-3 rolls of blue painters tape
-a sanding block
Other supplies you may need:
-newspaper or paper to tape up windows.
-220grit sandpaper
-a sanding block
STEP 3: Prep the Vehicle for Paint
First I needed to remove the pinstripe from the vehicle. I used a heatgun and a razor to remove the pinstripe.
Now remove all the parts you dont want painted off. (lights, roofrack, spare tire, etc)
Next You need to wash the vehicle.
After washing the vehicle you need to sand it down with 220grit sandpaper as shown in picture.
STEP 4: Wipe Down
After finish sanding you need to wipe the entire vehicle down with some Acetone or mineral spirits to clean the surface.
I then Painted the door jams so that I wouldnt have to go back and mess with it and it looks cleaner. (This step may require removal of some interior panels depending on model of vehicle. In my case I didnt have any really so I didnt have to worry about it.
STEP 5: Mask Off the Windows
After prep and doing the door jams. I needed to mask off the windows and lights so that I wouldnt get paint all over them. I just used paper I had laying around.
STEP 6: PAINTING!
Ok now for the fun stuff PAINT. Break out all the spray paint you bought and start spraying. Make sure your (insert nice car here) isnt parked nearby or you may get overspray on it. I advise you to do one complete light coat first then a final coat after. Krylon covers quite well. Coats may vary based on what kind of paint you use.
STEP 7: Remove the Masking
After letting the paint dry for an hour you can remove the masking on the windows. Should look something like the picture below. (Notice the numbers I stenciled on before taking off the tape.)
STEP 8: Reinstall Parts and Enjoy
Now reinstall the parts you took off (lights, roof rack, etc.)
STEP 9: EXTRA STEP
I bought a front bullguard and wanted to paint it to match the truck. So ill add this step in aswell.
1) Sand down bullguard with 200 grit sandpaper
2) wipedown with acetone
3) paint with duplicolor truckbed paint
STEP 10: Final Install
I installed the front bullguard and it looks like this: The second picture is a year later after I added zombie decals to it and got a new front bumper for it. As you can see the paint has held up fine even after beating it on trails.
68 Comments
Eli D S 6 years ago
farna 9 years ago
Find a cheap paint shop like Maaco in your area. They start around $300 in most areas for a basic paint job. Do all the prep work mentioned here except the wipe-down and masking. Also take anything off that comes off easy that you don't want painted. They can spray it with automotive paint a lot better than anyone can at home. It's not a show car job, but that's not what a project like this calls for. I've ad a few of my classic cars painted like this. The paint is good (I always used the mid priced job, which has a longer lasting paint), it's the prep work that makes a paint job. I always did my own prep and body work -- at least most of it. A couple times I had them do some more complicated body work, but that's where they make their money.
BenM213 7 years ago
Farna, that's brilliant. Any more specifics on what prep work you did before handing it over to the paint shop? Did you have to negotiate the deal for Matte Green by explaining you'd do some of the prep?
farna 7 years ago
XxTylerRichardsxX 8 years ago
Nice Job. What company makes that bullbar?
dreminofscremin 10 years ago
sam24th 10 years ago
rangerweavere 9 years ago
lucky me that i noticed this cause ive been looking to.
dantribble 10 years ago
The Jeep looks great!
HollywoodSnooks 12 years ago
Depends on the color, but probably about 4 if you go with a darker color and 7-8 if you are going with a lighter color. You could primer it first and use less coats if you like.
arabic 11 years ago
What year is your Jeep?
What are the lights on the roof basket called?
lastly, what are the lights installed on the bullguard called?
Thanks
-Arab
Jeep is a 1990 Jeep Cherokee Laredo
Lights on the basket are KC daylighters 6inch
Bullguard is a romik bullguard from Japan and the lights are PIAA 7inch lights.
kfield1 10 years ago
goodolejim 10 years ago
Mr Rancher 10 years ago
The Jeep looks great.
