Introduction: Hockey Table
(This is NOT a Air Hockey Table, you have been warned).
Is very easy to make, cheap and can be done in half hour.
I found a very good MDF board for the table, it have a smooth surface on one side, it was a bit more expensive than a regular MDF board ($39.89)
This is only the top of the table, that mean NO LEGS, you have to put the hockey table on a table, a very strong table. I will try to upload a design for the complete table soon
Step 1: Materials
MDF Board that measure 224 x 214 cm. and 1.5 cm thick and cut it as follow:
1x 122 cm. X 214 cm. (piece A)
4x 8 cm. X 107 cm. (piece B)
4x 8 cm. X 43 cm. (piece C)
4x 8 cm. X 30 cm. (piece D)
2x 4.5 cm. X 30 cm. (piece E)
the extra wood from the MDF, use on what ever you want
16x bolt with nuts
2x hinges with screws
Electrical saw
Driller
16x bolt with nuts
Electrical saw
Driller
Step 2: Work the Pieces
Use the electrical saw to round one corner on each of the four piece C, you can also leave the square border, it make a bit more hard to make a point, just rounded a bit
Now on the piece A, make a hole on where the porter suppose to go, this will allow the pocket to fall
Step 3: Attach the Borders
Use the pieces B and C and make the border over piece A, obviously have to be a open space over the cut make on the piece A
Use the bolts and nuts to secure the pieces, you can also use glue if you like
As you can see this is a very rustic table, but with a lot fun
Step 4: The Porter
Now come the pieces D, put one piece on the top and the other on the bottom of each porter, like a sandwich
The piece E prevent that the pocket fly away when a point its made, use the hinges to make some kind of door, that way is easy to retrieve the pocket
Step 5: Lets Play
I buy the puck and strikers from amazon.com., but sure you can find also on ebay and others. I thought this table for pucks of 2 1/2" diameter, you just make a bigger the porter if you want play with the 3 1/4" pucks
This table is very simple, cheap and easy to esamble, ideal for a weekend
