Introduction: Hocus Pocus Inspired Sanderson Sign
This is a pretty simple but brilliant hocus pocus sign. I bought a base file that had the top sign then copied the same style, made it smaller and flattened the top for the bottom sign. Added the text and skulls then made an offset around both signs of 0.1mm so lightburn could pick it up to engrave the majority and not engrave the text. Kind of like a negative.
Put some string to attach the two signs and make it hangable and job done.
Hope you like it.
Step 1: File Cleanup
So Step one,
Import the file into Corel Draw, As you can see the hook pegs were a bit messy so clean up had to be done. I cleared all colour so that it had no fill to see what the true image was. Turned out to be just a bunch of brush strokes so that was ok.
Next was to create the lower half of the sign. I simply copied the outline of the top half and cut the curve off at the top and the hook holes at the bottom. (see second picture)
Next was to offset the outline twice so it would give the inner outline using the offset tool. Then to copy the text font and the skulls and create write the Children stay free.
Step 2: Send to the Laser
Then it was just a case of pressing Start in lightburn and away it went engraving all of it and leaving the text.
