Introduction: Hole Distance Measuring Callipers
Maybe you measured hole distance with vernier calipers.
It's not exact cause hard to center its teeth.
Simple 3D printed parts can handle it.
Step 1: Hole Measuring Tool
It's like vernier calipers but its teeth is cone shape.
So cone's center must be hole's center
and can measure center to center.
Step 2: Design It
Draw cone and cut slit. The slit's width is your venier calipers's thickness.
Calipers' tooth should be center of cone. cut radius deep.
Step 3:
Now print. Mine are not peaky. but now just go on.
I made a bolt hole to fix but didn't need a bolt to fix it
And two cone's distance should be 20mm, but it's 21mm
Instead re-printing it I will minus 1mm.
Step 4: Measure Hole.
Now you can measure hole distance easily.
You can measure side to hole with one cone.
