Introduction: Hole in Paper Illusion
A very easy drawing of a hole in paper.
Step 1: The Shape
First create a thin, 3-4 inch wide, oval. Much likes the one seen. It doesn't have to be light but make sure it's not too dark.
Step 2: Basics
Next draw an arch starting from the middle left going up and then end on the middle right(the peak should be less than a centimeter).
Step 3: Detail
Next add vertical lines within the boundary of the arc and the smaller side of the oval. Also retrace everything in a darker shade.
Step 4: Shading/Coloring
This next part is very easy. Fill in the larger part of the oval with a dark shade, the whole things does not have to be covered. Now take a tissue and smear it within the lines.
Step 5: Shading/Coloring
Now in the smaller part of the oval do the same things you did in step 4, except in the smaller part of the oval.
Step 6: Finishing Touch
now take the tissue you use to smear everything, and rub it around the hole like in the picture.
Step 7: You're Finished
You're finished! please make sure you check out some of my other instructables!
