Introduction: Homade Rc Plane
Hello,I'm heron from indonesia I'm 13.Im going to show you how to make an easy rc plane from a broken rc car
Step 1: Collect Your Material
You will need:a rc car(new or old),a 3,3 v battery,2 motors,a large cardboard,a exacto knife,a glue gun,solder,and some tape
Step 2: Making the Body
Use some cardboard and cut a triangle(the size is up to you),I recommend 30 cm(height),30 cm(bottom),and then connect it.Make two of these then attach it using some hot glue and tape.
Step 3: Still Making the Body!
After you finish making the triangle,you need to cut another triangle which is about the same size as the edge of the larger triangle.then cut the covered area as this picture shown
Step 4: Wiring
Only take the board,antenna,and cut of those weak dc motors(it is not strong enough),then tape it at the body as shown.remove the vcc cables and attach it to the 3,3 v lipo battery(I recommend you buy a good lipo battery and not a Chinese made stuff like mine).If you have a rc car without a transmitter you can try to find what frequency it works with.I also lost my remote but I am able to find another one(27Mhz)
Step 5: Attaching Fuselage
You can make anything from a body of a b17,stealth bomber,anything that you like.i haven't make one but I will post my finished product soon
Step 6: You R Done
You have finsish the rc plane,attack anything you like fpv system etc,enjoy pls vote lol;)
