Introduction: Home Automation
Turn your home into a smart home, with this you can control all electronic devices in your home within a single app. But for this project, i catered to only controls all lighting at home. Everything made easily with Raspberry pi 3 and relay for controlling the physical switches and an app build from scratch to control the relay for the remote control.
REQUIRED MATERIALS
- Raspberry pi 3
- 8-Channel 5v Relay Module
- Micro sd card (8GB)
- Female-to-Female Jumper wire
SOFTWARE USED
Win32DiskImager
Step 1: Wring Raspberry Pi With 8-channel Relay
Wire according to the diagram provide above
Step 2: Setup Raspbian Lite on Raspberry Pi
Visit https://www.raspberrypi.org/downloads/raspbian/
Scroll down and download latest Raspbian Lite (current - Buster)
unzip the .zip file and you'll get an .img file
run Win32DiskImager
browse for .img file under "Image File" option
select correct drive "Device" (e.g E:\)
click on "Write" button to start the burning process
click "YES" when prompt
once done, insert your sd card into raspberry pi and power it on
Step 3: Update Raspbian
Set static IP to Raspbian before update, HOW?
Login into raspbian terminal
User: pi
Password: raspberry
type
sudo nano /etc/dhcpcd.conf
scroll down to all the way down and paste this lines of code
interface eth0 static ip_address=<your static ip>/24 static routers=<ip of your router> static domain_nameservers=<(ip of your router) 8.8.8.8> interface wlan0 static ip_address=<your static ip>/24 static routers=<ip of your router> static domain_nameservers=<(ip of your router) 8.8.8.8>
save it by pressing "ctrl+x" and "y"
finally reboot your pi, with "sudo reboot"
after success reboot, run these command to update raspbian to latest version
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade<br>
Step 4: Install Packages
Time to install all dependencies required
in terminal run these commands
sudo apt-get install nodejs
sudo apt-get install npm
sudo apt-get install git
sudo npm install pm2 -g
Check if everything install correctly by running these commands
node -v
npm -v
pm2 -v
git --version
Step 5: Clonning "HomeAutomationServer" Repository
Clone "HomeAutomationServer" repository from github
git clone https://github.com/khairmuhammad-ybh/HomeAutomationServer.git
once cloned, go into "HomeAutomationServer" directory and run this
npm install
All required dependencies required for the project will be install automatically
Step 6: Run Server With Pm2
Run server with pm2
type this in terminal to generate the path for pm2
pm2 startup
copy the generated command and paste into the terminal and execute it
lastly, start server with pm2, type this command, you should be in the right directory by now
pm2 start server.js --name "HomeAutomationServer" --watch
run this command to save the server into pm2 so pm2 will auto run your server on every boot
pm2 save
Step 7: Reboot Server
Reboot server with this command
sudo reboot
once rebooted, type this command to check if server automatically run after reboot
pm2 list
With that you have completed the tutorial for setting up the server running with pm2
BUT BEFORE TO END THE ENTIRE TUTORIAL, let me tell you that this is just half of the application, so, where is the remaining tutorial you ask, visit https://github.com/khairmuhammad-ybh/HomeAutomati... for the final tutorial to install the app on your device.
UPDATES
Download and install the apk provided here : HomeAutomation and give it a try
