Introduction: Home Automation Using Arduino Part-I
It’s not like any other home automation as we seen earlier. It’s controlling devices remotely what’s the difference. It’s because it can control from the world. You can control it using any device that have internet connection i.e. : laptop,android,iOS. As of first part it don’t have any proper security like login page. Login and other features like control device without wiring, fan speed controller, temperature monitor etc .
WHAT CAN HOME AUTOMATION DO? Make cooler home Increase home energy efficiency Saves lot of time and effort Makes home more safe Allow to monitor home from anywhere Make you more lazy :P
Features of our project:
1. Control more than 10 devices (depends upon which Arduino You use.Aduino Mega can control more than 30 devices :D B| )
2. Monitor status of our device ie that’s on or not.
3. Control devices from anywhere 4. Its using Arduino so low cost and easy to make.
Things that needed:
- Arduino UNO or Mega
- Ethernet shield
- A domain and host (you can use dot.tk for domain and 2freehosting for hosting both are free or use domain from 2freehosting ☺ )
- Internet connection
- Relay board (or you can make one )
- Testing lamp or led (if you use led don't need Relay board)
- Working brain :P
Step 1: Setting Up the Server
Create Domain name and Host
First of all we wanted a MySql database.for that login to the cpanel and click on MySql database.
switching to cpanel in 2freehosting is ,login to 2freehosting and click cpanel and then switch.it will goto cpanel
then click on MySQL Databases
give your own database name username and password
then go to phpMyadmin.then click on create table
then fill up with these values (table name as temp ,then id,device1,device2,device3) (shown in pic)
then click on save
next goto the sql tab paste this query and click go “ INSERT INTO `temp`(`id`, `device1`, `device2`, `device3`) VALUES ('1','ON','ON','ON') ”
then go back to cpanel.it’s time to upload files
download the files from attachment (server.zip)
and goto File Manager by clicking it
install the language then click on Open File Manager
then upload the server.zip and extract it we need to edit it a little bit. edit “server.php” file .for editing right click the file and goto edit file
in here we are inserting our mysql database details.
their is 3 field you have to fill.
1.$user = "username of MySql eg :u8425xxxxx_xxxxx";
2.$pass = "password of MySql";
3.$database = "u8425xxxxx_xxxxx";
you can find these at MySQL Databases @advanced tab.
fill up these things(needs double quotes ).and save .
check your site is it working properly or not.
Step 2: Setting Up the Arduino
step i: open arduino ide
step ii: install ArduinoJson Library.i have attached ArduinoJson.zip.download and install the Library file.(sketch-->include library → add .zip library -->select ArduinoJson.zip)
step iii:open the provided code with arduino ide step
iv : Find www.testserver.com replace with your hostname.
step v : upload code into the Arduino.
Setting Relay hope you know how to connect relay to arduino if you don’t know refer this for stuuping hardware: https://www.instructables.com/id/Controlling-AC-li...
The output port are 8,7,6 .so put relay input on these pins. if you don’t have relay board don’t worry you can test with led :) if you are using led interchange the HIGH to LOW and LOW to HIGH in the code
NOTE:its is not safe to use AC.so try n your risk.i would priffer using the led :)
Final Step insert the ethernet shield to arduino and connect to modem. If you open the serial port you can see something like “{"device1":"on","device2":"off","device3":"off"}” then its working :)
Open your site and try to change values.
hope it will help you guys.if you have any doubt feel free to ask :)
please inform me if anything goes wrong :D
Declarator : I am not responsible for burning your device :P ;) .do it your own risk.don’t play too much with the AC.
credits : Benoît Blanchon (https://github.com/bblanchon) -- ArduinoJson
