Introduction: Home Automation Using ESP8266 or NODEMCU
Ever wanted to make your home automated via wifi? Wanted to control the lights, fan and every other appliances from your smartphone? Or ever wanted an instructable about connected devices and getting started with it? This Home Automation project will show you how to make your home automated using an android smartphone. This requires you to have no experience of programming or electronics at all, as a free application and code plus schematic as well as pcb layout is included for you to develop. Using this android application you will be able to control your lights, air conditioning, door locks ,etc all from your smartphone. This system uses Wifi to connect with your device and control the various appliances in your home. Enjoy this instructable hacking tutorial!
Step 1: Tools and Materials
Hardware :-
*Nodemcu or esp8266
*Four 5V SPDT relays
*4 Amp MT Connecttors
*4 BC547 Transistors
*4 660ohm resistor
*4 diodes
*Copper clad sheet
*Soldering Iron
*Soldering Wire
*Flux
*Wire cutter
*5V DC Supply
*Any AC Appliance(For testing)
*Etching Solution
Software :-
Arduino IDE
DIY smarthome Android App
Step 2: Hardware Assembly
Step 3: Schematics and Layout
Link to all the gerber files for this layout- https://github.com/mayank007007/AutomationLayoutGe...
Above is the link to the gerber files which you would be required to take a print on pcb and after pressing and etching the layout on pcb you can start soldering the components on pcb.
And after all this it's time for code
Step 4: Programming the Nodemcu
Nodemcu
If you are new to the Nodemcu , NodeMCU is an open-source Lua based firmware and development board specially targeted for IoT based Applications. It includes firmware that runs on the ESP8266 Wi-Fi SoC from Espressif Systems, and hardware which is based on the ESP-12 module.
Steps :-
1.Connect Your Nodemcu to Computer
2.Copy paste the home automation.ino file which i have attached or open with the Arduino IDE
3.Upload the code to Nodemcu.
Step 5: Install the App
Steps-
1.Install the app and enter the ip address of your nodemcu which you can see in the serial monitor when you run the code which i have provided
Step 6: Controll Your Home Using Your Nodemcu
YOU CAN SEE THE WORKING OF PROJECT IN THE ABOVE VIDEO
BE CAREFULL WHEN WORK WITH RELAY ITS 240V AC .
