Introduction: Home Built Hydroponics Growing System
Hydroponics is an agriculture technology, growing food/flower without soil. Many different kinds of hydroponics method are available. It is beyond the scope of this instructable to comprehensively evaluate the pros & cons. In this instructable, I am going to focus on my current choice after evaluating them over the past many years.
Every approach has its pros & cons. My optimization is to minimize the labor effort to build the system by hand, and small size in terms of a backyard gardener.
This video taken on May 14th gives a system overview of my complete setup and its working principles. https://youtu.be/2OulpEGWKOE
This instructable can only provide a briefing on the hydroponic setup tested over years of operation. Hopefully it at least helps the reader a little bit when deciding whether to explore this way of agriculture or not.
Supplies for the mechanical structure
- 2-in x 3-in x 96-in Whitewood S4See Kiln-dried Stud https://www.lowes.com/pd/2-in-x-3-in-x-8-ft-Whitewood-Stud-Common-1-5-in-x-2-5-in-x-96-in-Actual/1000507375
- Wood Screws
Supplies for water system
- Charlotte Pipe PVC Sewer Main 4 in. D X 10 ft. L Bell 0 psi https://www.acehardware.com/departments/plumbing/pipe/corrugated-and-drain-pipe/43299
- 2-in Bi-Metal Arbored Hole Saw https://www.lowes.com/pd/CRAFTSMAN-2-in-Bi-Metal-Arbored-Hole-Saw/1000593877
- 27-Gallon (108-Quart) container https://www.lowes.com/pd/COMMANDER-27-Gallon-108-Quart-Black-Yellow-Tote-with-Standard-Snap-Lid/3551290
Supplies for electrical system
- Pump and timer
Step 1: Build the Mechanical Structure
Depending on the size of your garden, personal preference, you may choose to build an "A" shaped structure, or a square shaped structure. The function of the structure is to:
- make sure the gravity brings the nutrient water from inlet to outlet and returns to the reservoir eventually
- provide support for the vein to climb upward, such as the ropes dropping from the overhead beams
- strong enough since the mature plants can be quite heavy. I tend to add 45 deg supporting structure
Step 2: Water Flow Pipes
- Use a Hole Saw to cut 2" hole in the PVC pipe.
- each PVC pipe is 10 feet in length, you may connect multiple ones to fit your garden size, or your support structure frame size built in step 1.
- If you have "n" parallel 4" pipes, you need to 3D print "n+1" pieces of the STL file pvcPipeCap_v4small.STL. It directs the water to the perpendicular water collection pipe, then direct the water to the washing machine sewage pipe.
- A storage container as nutrient water reservoir.
Step 3: Electrical System
The key of the electrical system, which drives the nutrient water circulation, is not how expensive the pump or timer controller is, but the non-stop working.
I tried 30 sec watering every 10 minutes interval, vs. 3 mins every 10 mins, and they produce no observable difference in the sample size of 50-60 plants, for tomato and pepper.
We don't want the pump to run continuously because:
- all electrical device has a life expectation
- the root needs time to breath the air
I use solar panel to power my system, but that is an optional choice.
Step 4: Nutrient Water
The easiest way is to buy some liquid or powder concentrates. Follow the instruction manual and dilute it with the right amount of water. For example, I use some powder concentrates, the mixing ratio is 6 grams/gallon water. To fill my 27 gallon tank, it takes 162 gram of solid form nutrient.
Step 5: Choice Between Seeds & Seedlings
Starting from seeds is more difficult than starting from a seedling, since the seed starting is almost a completely independent topic to study.
Step 6: Observe and Study
After all, it is journey of discovering new knowledge.
