Introduction: Home Foundry
This instructable will take you step by step how to make a home foundry so you can make quick and efficient aluminum melts for casting. Its propane fueled so its easy to set up and easy clean. I hope it's informative and allows you to make castings of your own. This instructable is a result of my own research and trials I hope it benefits all those who wish to follow into the world of the home foundry.
This not the cheapest furnace but i had to buy a lot of my supplies. If you are a good scavenger/bargain hunter then your total price will be less than mine. Also propane compared to other fuels isn't the cheapest either, but it is clean and efficient.
Warning/Disclaimer: Working with molten metal is extremely dangerous. I do not claim any responsibly for any injuries or accidents that may occur during replication of this instructable. Always be safe when working with high temperatures and molten metal (don't do anything stupid and always wear safety equipment).
Do plenty of research and know what your getting yourself into.
Some references:
http://www.backyardmetalcasting.com/index.html
http://www.engineeringtoolbox.com/melting-temperature-metals-d_860.html
https://www.youtube.com/watch?v=lX6yFQNnk-A (this a charcoal foundry but there is still much to learn from it)
https://www.youtube.com/watch?v=B5wCVI7jCyQ&feature=related
https://www.instructables.com/id/My-Second-Aluminium-Foundry/step4/Refractory-Support/
Some references:
Step 1: Materials
Materials needed:
Burner:
-1/8" hex cap
-1/8" pipe (i used brass but steel would be better)
-1/8" to 3/8" brass fitting
-3/8" to 1/2" steel fitting
-1/2" steel pipe x3
-1/2" T pipe
-1/2" valve
-1/2" npt to 3/8" nptf fitting
- 1/2" to 1/4" reducer fitting
-1/4" x 2" pipe
-1/4" ball valve
-1/4" male quick disconnet
-3/4" steel pipe about 7" long
-Gas hose
-High pressure valve
Refractory:
-Portland Cement (crucial that its portland not masonry)
-Silica Sand
-Perlite (used in planting it is an aerated volcanic rock that doesn't absorb heat readily)
-Fireclay (i had no supplier of this but i used rutland refractory cement instead)
-Water
Furnace in general:
-Steel pots or pails (avoid galvanized apparently if they get to hot the zinc on them will release toxic fumes)
-1" id Steel pipe for burner inlet
-Drainage pipe about 2" long (leftover from making the burner inlet)
Crucible:
-Scrap sheet metal
-Scrap rod of various sizes (i used 1/4 and 1/8)
Various:
-Steel rod
-Cardboard
-Gaffers or duct tape
-Teflon tape
-Mixing tub
-Propane tank
-Set screw
Safety equipment:
-Welding Gloves
-Safety Glasses
-long pants
-flame retardant shirt or jacket
And of course lots of scrap aluminum to melt
Burner:
-1/8" hex cap
-1/2" steel pipe x3
-1/2" T pipe
-1/2" valve
-1/4" x 2" pipe
-1/4" ball valve
-Gas hose
Refractory:
-Silica Sand
-Water
Furnace in general:
Crucible:
-Scrap sheet metal
Various:
-Steel rod
-Cardboard
-Teflon tape
-Mixing tub
-Propane tank
-Set screw
Safety equipment:
-Welding Gloves
-Safety Glasses
-long pants
Step 2: Tools
Tools needed:
Dremel
Various bits for said dremel
-cutoff discs
-sanding drums
Sharpie
Paint auger
Respirator
Wrenches
Lighter
Cupcake pan
Air Compressor
Drill
Beating stick
Welder
Metal forming equipment (nothing major)
Dremel
-cutoff discs
-sanding drums
Sharpie
Paint auger
Respirator
Wrenches
Lighter
Cupcake pan
Air Compressor
Drill
Beating stick
Welder
Step 3: Burner
Start with the gas line:
Take all the parts for the burner assembly and wrap the threads in the teflon tape.
-Assembly starting from the tank end to the actual burner:
-attach the high pressure valve to the propane tank
-connect the gas hose to the high pressure valve
-next is the 3/8" nptf to 1/2" npt
-then 1/2" x 2" pipe
-then a 1/2" ball valve
-followed by another 1/2" x 2" pipe
-next is the T pipe
-on one side yet another 1/2" x 2" pipe follows
-the following part is the 1/2" to 3/8" fitting
-then the 3/8" to 1/8" fitting
-next is the 1/8" pipe
-on the opposite side of the T pipe is a 1/2" to 1/4" reducer fitting
-then there is a 1/4" x 2" pipe
-followed by a 1/4" ball valve
-and lastly attach the 1/4" male quick disconnet
Before placing the hex cap on a few things need to be done.
-a very tiny hole needs to be drilled in the 1/8" pipe (as small as possible) this hole must be facing as straight down the blower pipe as possible
-take the 3/4" pipe and drill a hole in the side so it can slide on the 1/8" pipe
-also drill two 3/8 holes into the top of the pipe
once the 3/4" pipe is slid onto the 1/8" pipe screw on the hex cap
next a set screw is need to keep the pipe form sliding or moving around
-align the tiny hole in the 1/8" pipe centering it down the 3/4" pipe
-screw the pipe in place (be careful not to puncture the 1/8 pipe
-i used epoxy putty in addition to make sure it doesn't move
-next is the T pipe
Step 4: Crucible
This i did at the shop at my school.
I took a 16 gauge steel sheet and cut it to about 5 inches high
next i rolled it to 4 inches in diameter and welded the seam
i plasma cut a base and welded that to the cylinder i just made
make sure the welds make a seal (it would be bad if molten aluminum leaked all over your furnace)
the main chunk of the crucible is made at this point but i had to think how i would lift it out and pour
i added two lugs (one on either side) which allows me to pick it up with the tongs i made
i also added a half ring on the bak to allow me to tip the crucible while i have it picked up
Step 5: Furnace
Take the two pots or buckets and decide the top and bottom.
Find wether it be big cans or whatnot to make the inside forms out of. you want them to be big enough that you can easily fit your crucible inside but not to big that there is a lot empty space
Burner inlet:
-cut a pipe that allows the burner to slide in perfectly it should be just long enough that it goes into the furnace but allow the burner to have the holes exposed
-cut a rod and bend it slightly as a support for the burner, weld this to the inlet pipe
Top:
-on the top cut a hole the size you want the opening to be (i made mine the size of a can because it was easy to acquire form to wrap the cardboard around)
- make this about the height of a can
-find a bigger form to wrap more cardboard around to get the main form cavity
-tape the opening cavity to the pot
- leave the bigger form for when you start parking in the refractory
Bottom:
-cut a hole in the bottom the size of the drainage pipe you made/acquired
-tape that down
-make a form the same size as the big one in in the top part (again wait to put in until you start adding the refractory)
-on the side pick a place to cut a hole for the burner inlet
-tape the burner inlet pipe in place
Burner inlet:
Top:
Bottom:
-tape that down
Step 6: Refractory
The refractory is probably the most important part of the project. This is because it not only keeps the keeps the heat from burning the surrounding area, but it also keeps the heat in the furnace which allows it to be more efficient.
While mixing prior to adding water wear a respirator the dust is nasty to breathe in.
To make the refractory:
-Use a 1 gallon bucket to measure the ingredients
-The mixture is made of:
-2 parts sand
-1.5 parts portland cement
-1.5 parts perlite (amount i used but more won't hurt since it does a really good job of keeping the heat in the furnace)
-2 parts fireclay or refractory cement
- Just enough water to keep the material clumpy (when there is extremely high heat involved you don't want too much water in the refractory (heat and trapped water don't mix well... boom))
- Steps to mix:
-in the big mixing tub pour the portland, sand, and perlite
-i used 2 gallons sand, 1.5 gallons portland, and 1.5 gallons perlite
-Mix with the paint auger and add some water to it (just a little)
-Next add the fireclay/refractory cement
-i used 2 gallons of it
- Mix all together and add more water till it clumps together (avoid soupy)
Once the refractory is mixed:
-Use your hands to pack the material in as tightly as possible (avoid any air bubbles)
-I used a 1-1/4" rod to help pack the material in
-When filling, pack the material around the parts that are taped down (ie. the drainage pipe and the opening form)
-Once level with them place the bigger forms in and pack the material in tightly around it.
I had extra refractory so i made two plinths that the crucible can sit on as well as a block that i can place the castings on when i pour.
-2 parts sand
- Steps to mix:
Step 7: Finishing Up
After about 2 days from mixing, the refractory should be solidified enough to take out the forms.
-Do this carefully so as not to damage the walls
After about 4 days from mixing the refractory should be ready to be fired.
Step 8: Firing Up
To fire up your newly completed furnace place the top part on the bottom part
-Next hook up the gas system (i.e. blower to both the propane tank and the air compressor)
-Place blower into furnace entry
-Turn everything on
-Adjust the high pressure regulator to about half way (in other words turn the knob several turns to crank up the pressure)
-Slowly turn the gas ball valve and light with your lighter and adjust the flame
-Slowly turn the air ball valve to make the torch
-Play around with both valves until you get a decent torch
-Wait about 15 minutes (to condition the refractory) then turn off the ball valves
Now for a melt:
-In the bottom part of the furnace place a plinth and your crucible
-Put some scrap aluminum in the crucible
-Repeat the steps above (except the last one)
-After about 15 minutes the metal should be nice and melted continue to place scrap in for another 5-10 minutes until full
-Finally turn everything off
-Take off the lid
-Lift the crucible with the tongs
-Pour the liquid metal into any molds you have made or into cupcake pan
-Turn everything on
Now for a melt:
-Take off the lid
Step 9: Results
Here are some of the ingots i got from my furnace using the small cupcake pan.
Step 10: Video
Step 11: The Future
In the future i plan on making an instructable on casting with multiple materials.
There are many different types of casting and casting methods.
Just to name a few:
-Lost wax
-Green sand
-RPM (rubber plaster mold)
-Lost Foam
Just to name a few:
-Lost wax
-Green sand
-Lost Foam
