Introduction: Home Made Digispark
Digispark is an ATtiny85 based microcontroller development board come with USB interface. Coding is similar to Arduino, and it use the familiar Arduino IDE for development. My digispark will be powered by USB only. Digispark is fully compatible with arduino.
Specification:
-Support for the Arduino IDE 1.0+ (OSX/Win/Linux)
-Power via USB -6 I/O Pins (2 are used for USB)
-6K Flash Memory after upload bootloader
-I2C and SPI -PWM on 3 pins (more possible with Software PWM)
-ADC on 4 pins
Step 1: Video Tutorial
Step 2: Montage
List elements:
2x 68 Ω
1x 220 Ω
1x 1.5K Ω
1x Diode red
2x Diode Zener 3.3V or 3.6V
1x USB plug
1x Attiny85
1xUniversal PCB
Step 3: Upload Bootloader and Driver Installation
Upload bootloader and driver installation
Link to package of files with devices and bootloader https://drive.google.com/file/d/1Gudu0x6EU9rCINJU...
Connect ATTINY85 with programmer
1. Download files
2. Extract Digispark.zip
3. You can find the bootloader file at micronucleus-t85-master\firmware\releases\t85_default.hex
4. Upload file t85_default.hex to ATTINY85
5.Set fuse:
Extended: 0xFE
High: 0xDD
Low: 0xE1
6.Install drivers Digistump.Drivers\DPinst64.exe
Step 4: Configure Arduino IDE:
Add link in Preferences to “Additional Boards Manager URL” http://digistump.com/package_digistump_index.json...
2. Install library “Digistamp AVR Boards by digistump”
3. Set Board: Digispark (Default – 16.5mhz)
4. Set Programmer :Micronucleus
Step 5: Test Our Digispark
Copy code or open in arduino Examples\Digispark_Examples\Start
Unplug Digispark before upload sketch and click upload. If you see the sentence “plug in device now” plug now your DIGISPARK. Now connect diode LED with pin number 5.
Have Fan :)
