Introduction: Home Made HEAT Boost
Have you seen the product which was made and shown on the Dragons Den?? Well there was this product which is meant to make your radiator more powerful on lower settings using two fairly small fans. So I came up with an idea of putting this Instructable together hope you like it.
I do give who ever made this invention full copyright meaning i do not take the role of inventer of this eco friendly tool.
Step 1: What You Will Need
You will need:
some kind of cardboard
2X CPU fan (I only used one)
A Ruler
Pens pencil
Scoring device can be a screw driver
An old power supply no more than 12Volts
Paper
and some radiator measurements
Selotape
I AM NOT LIABLE FOR ANY INJURIES DO THIS AT YOUR OWN RISK
A Ruler
Pens pencil
Paper
Selotape
Step 2: Measurements
Measure the radiator/s and make sure the fan you are using is going to be small enough as this will not work well. Then draw this out as long as you need on the cardboard. MAKE SURE YOU HAVE A TAB!!!
Step 3: Scoring
Score along the lines with a ruler to create straight lines so you get a nice even box shape but make sure you have got a tab. Then slice some neat even holes into the box to create some flaps on the bottom of the tube in the middle. now you need to move the fan in side, you can use superglue to finally secure and make sure you feed the cable along the tube. The fan needs to be about 8-9 CMs from the end you need to this on each side if you are using 2 fans. You also need the create a Flap beside where the fan is with the grill side of the fan showing through this flap(Like shown Below).
Step 4: Wiring Up
You now need to wire the fan up first using a multimeter find out which is positive and which is negative then connect either by plugs, Chocolate blocks or soldering. I used a Speed fan control unit to control the speed of the fan this also can be purchased from maplin this has a alarm so if it stops it bleeps it is advised that you don't run it for more than 6 hours. You can now test your final product.
