Introduction: Home-Made Sugru
I just came across this awesome and fairly new substance that is called sugru. Sugru is a whole nother class of silicon because it bonds to most materials, and when it sets this stuff is basically indestructible. I didn't really feel like buying this stuff online so i did some searching on line and came across this way make sugru and it was very cheap, in all it probably only cost me $4 to $5 to make around 9 ounces.
Step 1: What You Need
- silicon caulk (you can get this at any home improvement store)
- A paper cup
- A plastic spoon
- Corn starch/corn flour
- Food coloring
- A paper cup
- A plastic spoon
- Food coloring
Step 2: The Mix
Put the amount of silicon caulk you want into the plastic cup, the mix is 50/50 so you are going to want to put the same amount of corn starch in the cup as you put silicon caulk.
Step 3: Coloring It
You can color this any way you want but I used a few drops of food coloring and mixed it thoroughly until it turned the color I want
Step 4: Adding Water
Now time to add a very small amount of water, after you add the water mix it around and dump the excess water out. the mix is going to be a little soggy so add a pinch or so of corn starch and mix it in to the mix. now you should be left with a substance like play-do that you can mold, bend, and twist around.
Note: if your mix is still too sticky to use you can put some corn starch in you hand and start rolling the mix around in your hand.
Step 5: Finished
Now you don't have to go online and get ripped off by the sugru company you can just make your own sugru.
If you liked this instructable please check out some of my others
Please vote, favorite and subscribe to my instructables page,
feel free to comment on this,
Thanks!
Thanks!
