Introduction: Home Made USB Power Bank Very Low Price
Welcome to HOME MADE STUFF today I am going to show you how to make a USB power bank at home firs what's are the components are we need it
Step 1: Components & Tools
Ok let see the what are components of used this project
L7805 5v Linear regulators -10
0.33uF Electrolytes capacitor -1
0.1 uF ceramic capacitor-1
N 4003 Diode -1
Switch-5
220 ohm resisters -1
Green led light-1
USB port -5
9v battery-15
battery adapter -5
Mini pub board -10
This component total price-55Rs
Ok next What are the tools are need
soldering iron
Led
Wire cutter
Multimeter
N 4003 Diode -1
Switch-5
Green led light-1
USB port -5
9v battery-15
battery adapter -5
Mini pub board -10
soldering iron
Led
Wire cutter
Multimeter
Step 2: Temporarily Connection to All Wires
I am temporarily connecting all wiring you can see the all connections
This is 9v battery positive terminal and negative terminal the positive terminal connecting on/off switch then connect diode.
this diode one way only out going not incoming
then connect the 0.33uF capacitor positive lead to positive terminal and negative lead to connect negative terminal
capacitor positive lead connect to l7805 Regulator inlet pin Gun pin connect to negative terminal out put pin connecting a 0.1uf capacitor one lead another lead connect to negative terminal
Then capacitor positive terminal connect to 220ohm resister one lead another lead connect to LED positive Pin LED negative pin connect to negative terminal
The wiring is almost finished now we have a 5v positive and negative terminal hear
Then USB output pin connect properly positive and negative terminal
Step 3: Then Test It
Test is successful work
