Home Made Vertical Hydroponic System
Intro: Home Made Vertical Hydroponic System
I saw a vertical hydroponic system that I really liked but what I didn't like was the $500 price tag. I thought about it for a while and decided I could design my own system that is similar for much less money. After about a month of spending weekends running back and forth to the hardware store I came up with this system shown in the videos below. I call it The Rain Tower because there is a pump in the resivour that pumps the nutrients to the top of the tower and they rain down on the roots of the plants on the inside of the tower.
In this first video above is the test run I did growing 12 lettuce plants. The results were amazing as you will see.
In this second video I take you step by step showing you all the parts you need and how to put it all together. Links will pop up during the video but if for some reason you don't see them you can visit the web page here: The Rain Tower Home Page
23 Comments
gabigirlhs 7 years ago
Hi there.....I also posted this question elsewhere but the article was quite old-....
I also saw the same tower for 500$. It looks great but is pricey and doesn't get delivered to Europe... BUT, I really would like to make one myself and am at the beginning of looking into it. I just have one question. Why are stainless steel (or even glass) containers never used? I understand that they are far from cost-efficient and may be more difficult to build but it spares the risk of weird chemicals from plastics or PVC. Or is there something else that goes on that I don't know about yet so that stainless steel shouldn't be used??
jrmarchesini 1 year ago
kurtbelyeu 4 years ago
jsweet2210 4 years ago
michaelb2 7 years ago
What is the current best pump? I have burn through three sunsun jp055 pumps in less than a year
JacksonM35 7 years ago
I'm not at all knowledgeable about hydroponics, but I know a bit about aquariums. Your best bet is to go to a pet store that only deals in fish and ask them about it. Chances are that the owners and employees will own fish, and they'll have used pumps in the past. They're likely to know which would be best for moving the amount of water you want to move, how far you need to move it, and how many gallons per hour you need it to move.
IrvinH2 8 years ago
ArtisanEclectic 7 years ago
Epoxy is chemically inert when cured.
k2reme 8 years ago
like the design i have little different version that uses mist emitters and a single res for all the towers. not in production yet but it works well with one tower
tomithy1235 10 years ago
Why did you use the epoxy? It seems like a bad choice to be around plants and water for plants, just for safety concerns.
Is there any reason not to use PVC cement?
SleestaksRule 10 years ago
Yeah, I wasn't concerned about the post or pipe, both seem to be the same material, and I know PVC is safe. I had to order the fence post online, unfortunately, and I just looked and it looks like he uses PVC fence post cement, which does in fact appear to work well.
I guess my concern just comes in with the (minute, I know) amount of potentially malicious chemicals that could come with that. I know Schedule 40 PVC cement is supposed to be non-toxic (as it commonly holds water line connections together), but I'm also worried that it won't be strong enough to hold more of a joint connection like this, instead of just holding together two pipes that are stuck together with friction. I plan on trying it to see how it works, but maybe I'll research the PVC fence post cement more too, but not being made specifically to be drinking water safe scares me, but perhaps unnecessarily.
Thank you for your diligent information though, it's inspired me to build one, I just need the time to start the construction, now that all the supplies finally came!
myoungeleg 8 years ago
I know this was posted over a year ago, however, I just began constructing one of these hydroponic rain towers. I noticed that you seemed worried about PVC cement in your above post, and also noted that you mentioned that the strength might not be enough "..instead of just holding together two pipes that are stuck together with friction...
I believe the PVC cement involves a chemical reaction whereby the PVC is dissolved to an extent and when two pieces are put together (at a joint with the cement), the magic of bonding the 2 pieces begins to occur. I think the hardest part about using PVC cement here is that we are having to bond a piece to the side of the post.
I am planning on finishing up mine today and will likely use some sort of silicone adhesive. Also, in regards to toxins for the plants. I took advice from a soil scientists. If plants can't grow, then the solid has toxins. If plants do grow, its probably safe and healthy.
Cheers!
CarlaB1 9 years ago
oooh... that's good news! I didn't think that vinyl fence posts would be food safe. Is it just their product that's safe, or are they saying that all vinyl fence posts are safe? Did they give you any details about why it's safe? Thank you for your help!
SleestaksRule 9 years ago
Call the manufacture. 1-800-336-2383
They make it for Lowes and Home Depot.
Press 3 for the tech dept. Ask if it's safe for growing plants. Really nice guy there.
This is PVC 4 LDPA - Low
-density polythylene �" not known to leach toxic
chemicals
pat.elgee.5 9 years ago
Milk jugs are made with polyethylene. Water bottles leach toxins into the water, but milk is held to a higher standard.
CarlaB1 9 years ago
Thank you!
slo5oh 9 years ago
A lot of things like epoxy, PVC cement, concrete are toxic during their chemical reaction stage but are inert after that. Epoxy and PVC cement are used in home aquariums, but only AFTER they are solid. Even concrete can be used, but it can take several months before the concrete is done curing enough that it will no longer spike the water.
It's the chemical reaction that happens during the hardening process that releases toxins, once the reaction is complete, they become safe.
shortcircuitaz 10 years ago
I used aquarium silicone... good hold... clear... and fish safe...
got it at Home Depot in the Glue section
Thanks for the tip!
Just ordered some, I'll have to try it out. Looks like it'll be handy around the house a lot too!
