Home (Room) Temprature and Humidity Monitor With Web Based Chart - Raspberry Pi
Introduction: Home (Room) Temprature and Humidity Monitor With Web Based Chart - Raspberry Pi
About: Systems / Virtualization with nearly four years’ hands-on technical experience and exposure in multiple platforms such as Windows and Linux. Proven ability to design, develop and implement network or systems i…
Simple way to monitor your, Home ,room, garage small factory or any other places Temperature and Humidity from anywhere in the world via internet.
It very fun and very simple.
Step 1: The Concept
  • The Raspberry Pi will get the Home(Room) Temperature and the Humidity from the DHT11 sensor.
  • All the data will be POST to the web server via JSON RAW data method.
  • Data will store in a data base and publish to a chart.
  • We can monitor the Temperature and Humidity with the chart.
Step 2: Required Items and Pre Requests
Step 3: Connecting the Device
  • Make sure the power is switched off.
  • Connect the VCC to the +3 V.
  • Connect the DATA to the GPIO 4.
  • Connect the GND to the GND.
  • Power on the Raspberry Pi
Step 4: Setup the Python File in the Raspberry Pi
Connect to the Raspberry Pi via SSH or connect directly. select a proper folder or location to create the file.
example :Desktop
nano dht11.py
And Download the attached dht11.py file and copy the source to your file in the Raspberry Pi.
All the functions and methods i have explained in the code with comments.
My web server IP address is "104.236.91.122" and the web service PHP file is "/rpi/rpi.php"
Step 5: Setup the PHP Web Service
Download the rpi.rar file and extract the files.
Open phpMyadmin and create a new database example : "rpi_themo".
Download the "pi.sql" file and import to your new database. (i have inserted few sample data)
Change the data base credentials in the following files
  1. \rpi\db-con.php
  2. \rpi\temp\assets\php\getTemp.php
Step 6: Testing the Device
Connect to the Raspberry Pi and go to your dht11.py file location.
run the below comand
sudo python dht11.py
you will get something like this :
New record created successfully
if you get something like this :
no_data
don't worry this has a chance to lose data. This is because Raspberry Pi is not running at a real-time system, the delay in the program is not accurate enough, and sometimes that leads to a failure of transmission.we can run the program for several times can pick the correct result.
Step 7: Automating This Process
As you know in Linux we can run any script using cron jobs hence i have added a record in the cron jobs for run the script every minute. Use the following script for add the script.
crontab -e
add the following line in the bottom
*/1 * * * * sudo python /home/pi/Desktop/dht11/dht11.py
save and exit, for make sure the record has added. type the following comand
crontab -l
then you can see the record.
Step 8: The Chart
Now all done. open a web browser and go to the web server.
Example : http:// ip address or webs address>/rpi/temp/
then you can able to view a nice chart with the data.
Please free to comment and ask questions i would happy to help :).
i am working to add more sensors and get a full dash board in the future.
Raspberry Pi Contest
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    24 Comments
    ysmamaradi123
    ysmamaradi123
    2 years ago
    After importing the .sql what i shoud do remaining rpi file where can i put , and Change the data base credentials in the following files means what please guide me
    Samrid
    Samrid
    6 years ago
    Hello I tried your tutorials but when i try to run dht11.py then a error comes:
    How to solve this error?
    ERR_RANGE
    arshadzackeriya
    arshadzackeriya
    Reply 5 years ago
    Hi guys sorry for the late reply.
    That means your sensor is not detecting the GPIO ports.
    Make sure your GPIO numbers are same as to the PORTS assigned in the code.
    Thanks
    linhuetvnu
    linhuetvnu
    Reply 2 years ago
    Hi, i have this problem too. I think your codes in file dht11.py don't correct. Please help me :((((
    KokY2
    KokY2
    Reply 5 years ago
    Hi, i have this problem too. And i'm sure the GPIO number is correct as the port assigned in the code. Can you give some suggestion to solve ERR_RANGE?
    mimiya
    mimiya
    Reply 4 years ago
    i have the same problem ..please if you find the solution i will be thankful if you could help me
    JuriB
    JuriB
    Reply 5 years ago
    I got the same error.. i've double check i'm using gpio4
    did you solve?
    thanks!
    Juri
    HaP18
    HaP18
    Reply 5 years ago
    Can u do that? I have too ..... HELP HELP HELP
    tuann2
    tuann2
    Reply 6 years ago
    i have too. did you solved it ?
    kkagnets
    kkagnets
    3 years ago on Step 8
    it would have been nice to put some comments in your code
    林煊林
    林煊林
    5 years ago
    Hello u have done a nice work:)
    I followed your guideline but at the end when I python dht11.py, I got some error message as below:
    Traceback (most recent call last):
    File "dht11.py", line 81, in <module>
    sample_1 = { "nodata" : no_data }
    NameError: name 'no_data' is not defined
    what did it exactly happend on this?
    HaP18
    HaP18
    5 years ago
    Line $handle = fopen('php://input','r'); in rpi.php. What I must change that?
    HyperV2012
    HyperV2012
    7 years ago on Introduction
    Awesome project.. Well done..
    Quick question can we change between Celsius and Fahrenheit?
    arshadzackeriya
    arshadzackeriya
    yes we can, simple formula to convert the Celcius to Fahrenheit.
    Then we can use a Drop down in the Main page to view the Fahrenheit version.
    PraveenN3
    PraveenN3
    7 years ago
    Good work buddy. Well done
