Home Made DIY Grey Water System Water Recycling.
313,464
321
70
Introduction: Home Made DIY Grey Water System Water Recycling.
I have always hated flushing clean water down the toilet and wasting the water that goes down the plug hole.
So I decided to make my own grey water recycling system.
It is fairly easy to put together if you are technically minded. And doesnt cost to much compared to other systems.
Step 1: Basic Principle
The basic principle is when water goes down the plug hole from the bath shower or bathroom sink. It is collected in 2 soil pipes fixed to the side of the house, and then pumped up in to the loft to be stored in a storage tank ready to be used to flush the toilet.
here is a link to a larger image
http://sites.google.com/site/simonspagesproject/Home/grey-water-system
Step 2: Parts Needed
2 x 110mm soil waste pipes.
1 x 40mm waste pipe.
3 x 40mm fitting for 110mm soil pipe
2 x end caps screw on type
1 pump
1 one way valve
1 foam filter
1 storage tank with lid
2 ball cocks
Some 15mm copper or speed fix pipe.
2 magnets
2 reed proximity switches.
2 relays
Some cable
Originally I was going to use a 12 volt pump running from a solar panel. But the pump I had wasnt powerful enough to pump the water up to my loft so I had to use an old central heating pump I have from my old central heating.
Step 3: Assembling the Water Collection Pipes
To start with I laid out the 2 soil pipes and drilled a hole in the side of both of them at one end so I could fit the 40mm fittings and join the 2 pipes together. And glued in place the 2 40mm fittings.
You will need to make sure there is lots of adhesive on them and they are well sealed because there is quite a lot of pressure in the bottom of the pipes.
Then I drilled another 40mm hole in the top of one of the pipes so I could fit an overflow pipe.
Next I glued the screw on inspection end cap in the end of one of the tubes.
While the adhesive was drying I made up the cut off switch mechanism.
Step 4: Making the Cut Off Switch Mechanism in the Collector Tubes.
The cut off switch in the bottom pipe is basically a magnet on a pivoting arm. A bull cock. And a reed switch on the outside of the tube.
When the water level rises the ball cock pulls on the arm which moves the magnet against the side of the tube.
When the water level drops the arm drops back down and moves the arm away from the side of the pipe.
This I bolted to an end cap to be fitted in the bottom of one of the collection tubes.
With a 15mm fitting to supply water to the pump.
Step 5: Preparing the Storage Tank.
The storage tank will have one 15mm pipe from the pump one 15mm pipe supplying water to the toilet.
An over flow pipe. And a bull cock with a magnet attached.
And a reed switch which will cut of the power to the pump when the water level rises.
Step 6: Fitting the Pipes on the Wall
When all the tubes had dried I fitted the blanking end caps. One of them is the one with the magnet arm and bull cock fitted to it.
I bolted the two tubes together on the wall with a small peace of 40mm tube between them.
Then I fitted the over flow and the waste pipe from the bath to the top.
Making sure I had already installed the foam filter in the top of the pipe this is just held in place by chicken wire bent over the top of the pipe.
Step 7: Plumbing the System
I attached a 15mm copper pipe to the bottom of one of the collection tubes and plumbed it inside to a one way valve to keep the water in the pipe when the pump is off.
which is connected to the central heating pump.
Then I ran some 15mm pipe up through the house to the top of the tank in the loft.
Then I attached the overflow pipe to the top of the tank and a 15mm pipe from the bottom of the storage tank to the toilet.
Step 8: Making the Control Box
The control box is basically 2 relays. The relay wired to the collection tubes switch is wired as normally open. The relay for the tank in the loft tank switch is wired normally closed.
So when the water level in the collection tubes drops to low the ball cock drop causing the arm to move away from the side of the tube. switching of the relay isolating the power to the pump.
The relay in the loft is off until the water level get towards the top of the tank. Then the magnet activates the switch causing the relay to switch on which will turn off the pump.
When the tanks are half full the circuit will switch on the pump and pump the water from the collection tube to the storage tank until ether the collection tubes empty or the storage tank is full.
Step 9: Wiring the Control Circuit and Pump.
I ran some bell wire from the reed switches to the control box which I mounted on the wall next to the pump.
Then I wired the pump up to the control box.
As shown.
Step 10: Testing
To test the system I ran the bath and allowed the water to go down the plug hole and to start filing up the collection tubes.
I checked the tube for leaks if I found any I had to empty the water and apply more adhesive to the pipes to try and seal the leaks.
When the adhesive had dried I ran the test again to find any more leaks.
When I was satisfied there were no leaks I was able to test the rest of the system.
I switched on the pump and made sure there was no air in the system. And that the pump was powerful enough to pump the water to the tank in the loft. And checked that the loft tank was not leaking.
Then it was just a matter of waiting for the pump to pump enough water in to the loft tank so that the water level in the collection tubes droped enough to activate the switch and turn the pump off. At the same time I manually checked the switch on the storage tank would switch off the power to the pump when the water level rose to high.
When I was happy the switches were switching the pump on and off correctly.
And the pipes were not leaking and the overflow pipes were working correctly.
I put the lid on the loft tank.
And went and had a shower and allowed the water to fill the collection pipes, the pump switched on and the loft tank started to fill.
Then I just flushed the toilet to make sure it would fill up and there were no leaks.
And that was it.
Step 11: Update Fine Tuning
Hi
I have been using this grey water system for about 6 months now.
In this time I have had 1 or 2 small problems that I have had to sort out.
The first one is, I have had 2 switches fail. I have put this down to the switches not being able to cope with the current drawn by the relays so I have made a simple transistor circuit to reduce the current going through the switches this has also enabled me to use just 1 relay.
see attached circuit diagram.
the second problem has been when the weather gets hot there is a bit of a smell from the grey water stored in the tank in the loft.
I have calculated that the tank in the loft is holding to much water for to long.
It is holding enough water for 5 days. so I am replacing the tank in the loft with a smaller tank which will hold enough water for 1-2 days. then more of the water will be stored in the tubes outside. and the water will be recycled sooner. and won't be sitting around getting smelly.
Earthjustice United States of Efficiency Contest
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    70 Comments
    jenlynnlarson
    jenlynnlarson
    2 years ago
    I like all the ideas here! I'm researching a set up for my RV, so that less water is needed. I will likely use a composting toilet but I like the simple idea of a sink above the toilet for the next flush.
    FrankE45
    FrankE45
    5 years ago
    Brilliant idea. PS Sinks are in kitchens, basins in bathrooms
    andred12
    andred12
    7 years ago on Introduction
    hi guys, i have rerouted my bath,basin,shower and my washing machine pipes, it flow into a 1000l tank in the ground.from there it pumps up to a 5000l water tank, and gravity feed my toilets and a tap so i can water my garden and grass, it worksgreat, one problem. The water has a strong smell in my toilet tank, what can i ad in the 5000l tank so it can reduce the smell? it starts to smell very strong. i safe about 7000l a month,
    i have also 2 x 1000l tanks to catch all my rain water up for filling my swimming pool and watering my veggie garden, there i save 4000l a month. ill post some picture of my hole system.
    i anyone can help me to remove the smell out of the water ill be very glad
    TamiJ12
    TamiJ12
    Reply 6 years ago
    Thank you for the info. I would very much like to see pics and instructions for your system
    AliciaS38
    AliciaS38
    Reply 6 years ago
    Chlorine dioxide is what is safely used to clean water in water districts. I would look into it. It is a safe product to the extend that it is used to treat water we eventually drink so don't be discouraged by the name. Good luck!
    otrcomm
    otrcomm
    Reply 7 years ago
    There are citrus based biodegradable additives for RV gray water tanks. TST makes several and you can check Thetford products.
    EricF122
    EricF122
    6 years ago
    how does hot water and soap scum, hair etc. affect the performance of the pump
    JohnM738
    JohnM738
    6 years ago
    Another option to move bath/shower water - - www.siphonaid.com under $20 - use it whenever that rose bush or tree is thirsty. No plumbing, construction so not likely to need a permit - just a garden hose and a window. Your bathtub becomes your indoor rain barrel and the SiphonAid is nothing more than a High Tech bucket that can save some labor - and your back.
    IgorT6
    IgorT6
    Correct me if I'm wrong, but in yours proposed system, if you don't collect enough gray water by just not using enough shower/bath/sink and/or by extensive using of toilet(s) -- you are at risk of not having water in yours "water storage tank", thus in toilet tank(s) after natively producing next crap. Isn't it?
    I love the idea that plumbing can help people conserve resources in their own home! Definitely something that more people need to set up!
    chrys.clay
    chrys.clay
    8 years ago on Introduction
    This may sound a bit cumbersome [ or lazy depending on your pov ] but I use 2 litre transparent lemonade bottles, fill them up from my bath, put them on the garage roof so that the sun kills any bacteria [ google SODIS ] then pour the water into the cistern after flushing. It saves about 55 litres a week on average.
    jun_n_venie
    jun_n_venie
    I am thinking or planning the same project, recycle bath water to flush the toilet. I would need to reroute bathwater pipes and install a new pump and a water tank and reconfigure the toilets to get water from the tank.
    Another e-friendly project I'm thinking of is a water-to-water geothermal water heating/air cooling system. Since water is always cold coming in and by harnessing the power of the sun, it could not only save money on gas/electric bills, its e-friendly!
    andrewuk
    andrewuk
    10 years ago on Step 11
    How do you protect against the outside pipes freezing?
    Pindell
    Pindell
    I'd go with the assumption that this one is built in warm climate. You'd likely have to build it inside if you have actual winter.
    (I realize your post was a year ago, but whatever).
    avery48
    avery48
    Really loved this. I am on a well and septic system. We have experienced a rather substantial amount of rain this past year, which has taken us out of a 15 year drought (not a CA style drought). Never the less, we have 5 adults and two small children, lots of bathing, dishes, laundry, etc. Did I say "laundry"? Anyway, with the extensively higher water table, and a septic system installed early in the drought when the soil actually perked, we have water noticeably coming up and flowing on top of the ground during laundry days, it really is the only time it happens. I was contemplating using the grey water for the garden. I think I can adapt your system for that and add the toilet system, serving duo purposes of recycling and conserving fresh water. Thanks you for the inspiration and motivation.
    altomic
    altomic
    13 years ago on Introduction
    excellent. very excellent. thank you a neat thing that I saw i Japan was when you flushed the toilet there was a tap and sink on the top of the cistern. so you push the button, toilet flushes and water starts running from the tap in to the sink which then goes in to the cistern to flush next time. the sink and cistern were one unit.
    iPodGuy
    iPodGuy
    Reply 13 years ago on Introduction
    That would only put out cold water, no? Not so good for washing with soap and killing germs.
    Broom
    Broom
    I think you missed an essential point:
    The system recycles from the sink to the toilet.
    You wouldn't want to wash your hands in recycled greywater.
    iPodGuy
    iPodGuy
    Yeah, I got that. What altomic was saying is that there's toilets out there with a spout that puts out water for you to wash your hands with. The handwash water then fills the tank of the toilet. That is greywater recycling, but toilets are cold water so all that would come out of the spout is cold. That was really just an observation I made. The system featured in this i'ble is well-thought.
    roosta
    roosta
    im not sure thats quite right. why couldnt you put hot water into the cistern? the way i read it is that the taps (hot and cold) are on top of the cistern pumping fresh water through fromt the mains. flush the toilet, cistern empties, turn on the tap(s) and the waste water from washing fills the cistern. obviously if you just swapped out your toilet for one of these you would only have a cold water pipe there, but you dont need the old sink either so you may as well put the new toilet where the sink was and then you would have both hot and cold pipes present. then again pipes can easily be moved using flexible piping. i dont know how old this product is by i had a similar idea when i was 14 (2004-2005 time) where the bass and seat of the toilet slid out from under the cistern, and the sink was mounted on top. we were trying to fit a toilet and sink in an under stairs cupboard, but there wasnt enough space.
