Introduction: Home Made Arrow Quiver
I needed a cheap and easy way of storing my arrows and transporting them. I found using a PVC quiver is both of that. This is really easy to make and works really good. Pretty much all you need is PVC pipe, an end cap for the PVC and paracord for your sling. I had a random sling around that I tied the paracord to for the sling.
Step 1: Supplies:
two inch PVC pipe
two inch PVC cap
shoulder sling
paracord
camo duct tape
Step 2: Tools
Tools:
Drill- drilling holes for paracord for sling
Recpricating saw- cuting the PVC pipe
Sand paper- sanding down the cut PVC pipe
Marker- marking PVC for cutting
Tape measure measuring PVC
PVC Glue gluing PVC cap on PVC
Step 3: Making:
The first thing your gonna wanna do is to decided how long you want your PVC holder to be.
I cut mine to two feet long.
Glue 2 inch PVC cap on the two foot piece of PVC.
Drill two holes on on each end of the PVC in line with each other.
I used a 3/8 drill bit for the hole.
I had a sling laying around that was broke that I tied para cord to for the sling.
You could use just paracord for the string as well.
Step 4: Using
add arrows and adjust the sling to a good size that fits you.
