Introduction: Home Made Hair Bleach ( FOR EXTENSIONS ONLY)
PLEASE READ:
Before i go into the actual instructions please please PLEASE do NOT use this on your real hair!
One of the ingrediants for this method is cleaning bleach! This will burn your skin and snap hair! I would only ever use this on old hair extensions if you are desperate to lighten them.
Step 1: Gather and Mix Ingrediants
For the ingrediants i used:
2 Tablespoons of honey
1 Tablespoon of Vanish Oxi Action stain remover
1 Tablespoon of baking POWDER (baking soda will work much better)
1/4 of a cup of 30 volume developer (Add more to make the consistancy runnier)
1 Tablespoon of liquid cleaner bleach
Mix the first 4 ingrediants then add the bleach. You will see a reaction as the bleach is added and the mixture will foam up.
Step 2: Apply to Extensions
Roll out some foil or cling wrap and lay the first weft down.
Paint a heavy amount so they are generously coated ensuring they dont dry out and further wreck the hair.+*
Leave for 40 mins.
Note: At 40 mins my hair wasnt quite light enough so i added more bleach straight onto the hair while it had the mix on it and left that for 10 mins.
Step 3: Rinse and Dry
Rinse hair after the time is completed.
If you wish to remove yellow tones, tone the hair for 3-5 minutes.
Dry hair and finished!
Note: yes, hair WILL fall out if you use this method, so please if you dont want to damage extensions dont do this.
