Introduction: HomeMade Modern DIY Xmas Tree
My friends at The Home Depot asked me to design a holiday tree project out of plywood as part of their DIY workshop program. I wanted to design a tree that could work both outside as a yard ornament or inside as a reusable Xmas Tree. This 3-dimensional plywood structure can be decorated in many different ways and can be disassembled and easily stored for future use.
Keep your eye on The Home Depot Apron Blog for updates and different variations of this project.
Step 1: Download the Xmas Tree Plan
Click here to download the Wood + Concrete Kitchen plan.
Step 2: Supplies + Tools
Available at Home Depot
Purebond uses a formaldehyde-free technology to make plywood that’s better for your family and the environment. It promotes healthy indoor air quality due to its proprietary, soy-based adhesive (instead of potentially hazardous urea formaldehyde). Traditional plywood contains a lot of glues and adhesives that can off-gas formaldehyde into your home.
1 1/4" + 2" Screws
I used basic deck screws to connect the plywood pieces, two 2" screws for connecting the cross support pieces and 1 1/4" screws for the rest of the connections.
Square
Ruler
Sandpaper
LED Mini Lights
I used 30 feet of mini LED Christmas lights to light the tree.
RYOBI 18 Volt Cordless Drill
RYOBI 18 Volt Circular Saw (with Plywood Blade)
RYOBI 18 Volt Orbital Jigsaw
Step 3: Pick Your Plywood
I selected 3/4" Purebond Birch veneer plywood, but any 3/4" thick sheet of plywood will work. There are a lot of different options and this desk could look really cool with any of them. I had one of the nice Home Depot associates cut the top and bottom of the desk for me. This saves time and also makes it much easier to get the plywood home.
Step 4: Mark the Cuts
Use a pencil to draw the cut lines on the plywood (as shown in the diagram below). I used a right angle square and ruler to make sure my lines where straight and square.
Step 5: Drill the Corner Holes
I drilled 5/16" diameter holes in the corners. This allows you to easily insert the jigsaw into the panel and connect the holes with simple straight cuts.
Step 6: Cut the First Profile Pieces
Step 7: Use the First Profile Piece to Trace the Cut Lines
Step 8: Cut the Rest of the Profile Pieces
Step 9: Cut the Support Pieces
Step 10: Notch the Supports
Step 11: Sand the Edges
Step 12: Assemble the Tree
Step 13: Decorate
I used LED mini Christmas lights to make this tree glow, paper and push pins to turn the tree skeleton into a modern white paper lantern and wire to add traditional ornaments.
