Homebuilt Camper Trailer
349,223
1,701
112
Introduction: Homebuilt Camper Trailer
Safari BaseCamp 10 is a homebuilt camper trailer that my dad and my brother and I built, with the help of some nearby craftsmen. One of the goals has been to create a self-sufficient system that facilitates a complete set of commodities without the need for hookups. Although many details were worked out during construction, there was quite a bit of prior planning and dreaming involved. It's probably been over two years since the building began, and we're still not done tweaking it. We took BaseCamp 10 on its first camping trip about a year ago.
Since Dad did most of the work and we boys helped with some things along the way, I may use "we" to refer to all or any of the the three of us throughout this instructable.
The project was based on a 4x8-ft. aluminum trailer frame. We replaced the wooden floorboards, the jack, the coupler, and the taillights and added other lights on the sides and rear of the frame. We also had it outfitted with a new 2,000-lb. axle, new alloy wheels, and new tires and had the fenders repainted. We would eventually have a local machine shop reinforce the tongue and mount a K & W diamond-plate-style toolbox above it.
Dad designed and built a 34-in.-high exterior-plywood box that would eventually sit atop the trailer. We painted the box olive, inside and out, and spray-painted a camouflage pattern in flat colors around the outside. More than one try was needed before the camo was satisfactory, but we finally settled on a simple hand-sprayed design under a stenciled Reelfoot bark pattern.
The box contained three main compartments. For the one in the front, Dad built a slide-out kitchenette featuring an Atwood WedgeWood two-burner cooktop, a sink, a faucet, a paper-towel bar, two drawers, and a storage area under the sink. The box and lid of the kitchenette are plywood, and the countertop is stainless steel-style Formica.
We outfitted the middle compartment of the main box with a 20-gal. water tank as well as a pump. One hose can be connected to the faucet in the kitchenette while the other is run outside for bathing.
In the area above the front and middle compartments, we installed a 12w 5a solar panel on a slide-out system. The panel charges two batteries located in the toolbox in front, and the batteries supply power to the water pump, five LED lighting fixtures, and three 12v outlets. An Amish craftsman helped to get the electrical system properly wired.
The largest compartment is the storage area in the rear of the box. A door on each side and in the rear allow access to the contents. A spare wheel and tire are mounted on the large rear door.
A protruding door opposite the one for the kitchenette allows access to some electrical components, including the the battery charger. A recessed compartment on the outside of the main box holds two small propane tanks–one feeds gas to the cooktop in the kitchenette, and the other supplies a portable Coleman water heater. An axe and a shovel are mounted on one side of the box, and a metal gasoline can is secured on the other. A Formica-topped table can be attached to the outside of the box on the same side as the kitchenette.
On a custom rack on top of the box, two 48x92-in. sheets of plywood provide the base for a folding rooftop tent that opens to nearly eight feet square. The aluminum frame, the canvas, and the mattress were fabricated by skilled Amish craftsmen. The results were exceptional, and the tent is capable of sleeping the three of us very comfortably. Two ladders support the overhanging side of the tent and provide access to the two doors on that side. Awnings protect openings on three sides, and a canopy extends out the other side to cover the kitchen area. Additional pieces of canvas can be used to further enclose both the kitchen area and the space under the tent overhang–that includes a floor for the kitchen area.
We also added these free-standing accessories: an Engel portable AC/DC refrigerator/freezer, a camouflage Honda EU2000i portable generator, and a fire extinguisher, and a Cabela's shower tent.
Using a homemade stencil, we sprayed the name Safari BaseCamp 10 onto both sides. We chose the name because it was 2010, and this particular camper happened to be about the tenth major camping unit my dad had used in his lifetime.
Here is a list of costs incurred during the build (note that this estimate does not include trailer chassis, shower/toilet, generator, and refrigerator, as well as flashlight, fire extinguisher, and shovel/axe with with mounts.
Wood: $666
Hardware: $1,195
Paint: $717
Plumbing: $255
Propane: $314
Electrical: $1,041
Miscellaneous: $355
Solar Power System (with associated hardware): $997
Tent: $3,869
Side Room: $2,029
Total for Basic Camper Trailer Build: $11,438
Summer Camping Challenge
Runner Up in the
4th Epilog Challenge
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    112 Comments
    vinyard
    vinyard
    3 years ago
    There are many types of Amish. Each community decides what their own rules are. Most choose not to allow electricity, but many do. There are even some Amish that allow the use of cars.
    zavierhodges
    zavierhodges
    Question 4 years ago
    what are the dimensions of the trailer
    (length and width)
    JakeM147
    JakeM147
    What model and type of trailer did ya u use!?
    frank kd0hgi
    frank kd0hgi
    5 years ago
    I wonder if anyone on here has done a cargo trailer to camper conversion some of us older folks need a toilet and shower, and most rv trailers cost too much need a simple trailer to camp sleep in that also has a wet bath in it, your build is pretty cool but like I said I need a toilet and shower if I ever got a camper.
    glorybe
    glorybe
    6 years ago
    I would find the need for a toilet to be a basic requirement.
    Rapturee
    Rapturee
    7 years ago
    I found my tent at CVT, they're out of Oregon. I'm sure there are other distributors around the country...and then you can always use ebay and they'll deliver it to your door. I know Tepui also makes them. I'll upload a pic of mine tomorrow if i remember, lol. Enjoy your Rooftop tenting!
    ScottE4
    ScottE4
    7 years ago on Introduction
    And that $666 for the wood was a bit obvious... but what gets me is that I am the only one that smells the meadow muffins
    anthonyschr
    anthonyschr
    Posting this project and seeing the great response was fun, but I've been terrible at keeping up with questions and comments. However, when I saw these, I had to jump back in. I somewhat understand the issues you're bringing up, but I think your conclusion might be mistaken.
    First of all, as the one of the sons in this project, I don't have a perfect offhand explanation for the prices. If I recall correctly, Dad gave me that price list in some form. Perhaps the paint was so expensive because it wasn't a professional job (much was wasted). I'll agree the $666 for wood is odd...or maybe not odd enough? :)
    As for the electricity—trust me on this one. While the Amish may live off the power grid, that does not mean they are strangers to electricity. Their lifestyle is probably the reason some of them specialize in low-voltage systems, LED's, batteries, and generators. Our project happens to use all of these, and who better to help us than an Amish man?
    Thanks for your comments, and I hope this helps clear things up! -Anthony
    ScottE4
    ScottE4
    Anthony, having worked with the Amish on a regular basis, purchasing and breeding draft horses, I have to call foul on that. they don't use ANYTHING electrical, as they refer to it as the "life force of Lucifer" they even use oil lamps on their buggies at night, and the only time they will even touch a light switch is during their adolescent Rumschpringe when they enter the "English world" before settling down to an "adult" sequestered Amish life, at which point they will only deal with outsiders who are willing to work with them in the Amish world. If there was someone similar helping it was more than likely a Mennonite who are a sect similar to the Amish, but live in the 21st century
    AS for paint costs, unless the entire thing was rattle canned which would be entirely foolish the paint cost was absurd, the wood would ( that drove spell and grammar check into a fatal error) best sealed with a brush which would have cost about 20-25 dollars with half the paint left over from a gallon can, and then the rest hand brushed and a final coat sprayed preferably with a compressor and low pressure, high volume gun all told under 100 bucks for paint. Ive been painting cars and trucks for decades and the box with its size and shape is very simple which translates to low volume paint use. My conclusions are based on real world experience. And between these things not coming together, and the timing I couldn't help but believe this was an April fools Joke, and a Prime one at that, especially considering the lack of instructions. Now with that said, it IS obvious from the photos that it is hand made and more than likely home built (Not a denial that you did it, just based on the lack of detailed instructions and accompanying photos). I know many people with the skills and tools to do this so I would be foolish to say "you didn't do this, someone else did, besides, I'm not Barack Obama ;-) It is an excellent build, there are a few things I would have done a bit different. such as adding a cabled light control pod for in the tent, and several telescoping poles with area lights on them, controlled by 2 way switches one of which would be on the "tentpod". a small sound system (stereo) with built in speakers on the trailer and a wooden hard top to cover and protect the tent when not erected, that would serve as a table when not on the trailer. the legs for it could be made from simple steel structural tubing that would serve as a canoe or kayak rack when the cover is on the trailer, Also this hard top would supply the means to set up a 45-90 watt solar system on the trailer for constant charging, even while being towed. with the correct panel choice they wouldn't need to be removed from the "table top" and the table could be used at two sides around it OR multiple panels removed and set up on a ground mount Or the to used at the basis if the ground mount itself. That's the great thing about doing it yourself, you decide how you want to do it.
    One more thing, none of this is intended as insult or in anyway an attack, some things are difficult to word in the manner they are meant, and like I stated, from my experience the "numbers didn't add up", and the date that this was refreshed, made it look like an april fools joke. As for the final product, it IS prime and is something I myself would proudly use, so one of my comments are meant to take away from that
    tnsoftailrider
    tnsoftailrider
    ScottE4, you are the one who is incorrect. Every Amish community may not be exactly the same. I hunt in Ohio east of Columbus. Every year we take our deer to an Amish processor who processes our deer along with a few hundred others. Though he is not connected to the electric grid he is connected to natural gas which in turn provides the fuel for a very large electric generator to power the large coolers and freezers needed to process meat. In addition, his neighbor is a furniture maker. My brother has had several pieces made by him. His shop is the size of a large grocery store and it is powered by a 250KW, 480 volt, 3 phase generator which is also fueled by natural gas. Since they both need items delivered by UPS and FedX, they both have phones, but not in the house. They are located in the outhouse.
    SethD4
    SethD4
    7 years ago
    So that 1000 dollar tent was because they paid someone to build it for them and the electrical system with the lights and water heater and whatnot most of cost went to paying someone to instal all of those things.
    Tangski
    Tangski
    Oh, and for this cost, I would personally just buy a TAB trailer, just as light....
    Tangski
    Tangski
    A word on finishes. Yes, wood can be just fine...there is a new epoxy paint/covering perfect for this as it is now used on commercial signs! And the cost is no more per gallon than very good paint! It comes in two parts, can be rolled or sprayed and is GREAT for this kind for project! lasts years, water proof, UV proof ect....pro's use it now a lot! And it looks great. You can add layers as well, to a thicker exterior, remains flexible enough to weather very very well. I plan to use it on my project too. Along with oil asphalt on the bottom (can't afford the aluminium stuff...darn, but that's life...) Hope this helps. Can be added over this paint job too! Hey, how cool is that! It is also used to give styro foam a hard exterior impervious to weather! Many sets are built in movies using this stuff. 'Styro- spray' is one source. Cheers! happy building!
    JohnM17
    JohnM17
    Would you share the information about your custom tent? I need to have one put together for my project. Thanks.
    anthonyschr
    anthonyschr
    Thanks. The plywood box is definitely a weakness, as joints can move, allowing moisture to invade. We have the frame at a shop right now to repair and reinforce it after a pretty major failure. Short story: we arrived at Joe Nall last summer with the trailer hanging at an odd angle. The tongue's connection to the frame had been seriously compromised. We're fortunate that we made it there.
    ScottE4
    ScottE4
    "An Amish craftsman helped to get the electrical system properly wired."
    Come on, they don't believe in electricity... Its getting deep here!
    ScottE4
    ScottE4
    While it is an impressive build, when I see these prices in the list, I have to say, April Fools Day is over
    ScottE4
    ScottE4
    $717 dollars in paint? there isn't that much in paint in a custom car paint job utilizing lacquer or even a boat using epoxy based paint.
