Introduction: Homemade Air Conditioner (a/c)
Hiii
I'm back with air conditioning project.
This is a simple Homemade, portable, 12V DC air conditioning system.
So guys you can make one using the following steps.
Step 1: Parts Required
  1. Plywood
  2. Old radiator fan
  3. Old windshield washer pump
  4. 12V 4A power supply (you can use a computer SMPS also)
  5. Copper tube (5 mm diameter)
  6. Tube connectors
  7. Electrical components ( detailed in step 3 & 4)
  8. Soldering iron
  9. Driller
Step 2: Plywood Preparation
Cut the plywood in required length.
Length will depend upon the radiator fan.
After cutting put holes for attaching copper tubes.
Make holes for switch & LED too.
Cut copper tubes also.
Step 3: Make Circuit for Pump
Circuit 1
Why i used a circuit for pump ?
It is not required run the pump continuously. So i made a repeating timer circuit.
I made it for 1 min on & 1 min off . Refer this to get more idea.Repeat-Timer-Circuit.
Give connections as per the circuit diagram given.
Step 4: Make Speed Control Circuit for Fan
Circuit 2
Speed controlling is necessary for a fan, i made a simple pulse width modulator for speed controlling.
Components needed
IC NE555
Diode 1N5815
VR 100k
MOSFET IRF 530
Capacitors 10nf, 0.1nf, 470mfd
Step 5: Assembling Plywood & Parts
Make a plywood box & attach switches, LED & speed controller.
Step 6: Fixing Fan & Giving Connections
According to connection layout give connection to fan, pump, circuit 1 & circuit 2.
Step 7: Fixing Copper Tubes
Now fix the copper tubes in previously drilled holes. Connect each copper tube using hose pipe from pump & finally to the collection tank.
Step 8: RUN A/C
Make sure all the connections are correct, Now pour a bottle of cold water to the collecting tank & turn on the pump & fan.
WooHooo your A/c Ready...
