Introduction: Homemade Clamp From PVC Pipe
Hello!
Clamp, it's a cheap tool. A few pieces are enough to always be at hand. But if a large number of Clamps are required, then the cost grows significantly. It is good that you can make a clamp with your own hands. The model is simple to manufacture and easy to operate. To make the clamp you will need a piece of PVC pipe. The thicker the walls, the greater the compression ratio.
Step 1:
1. You need to cut the pipe lengthwise
Step 2:
2. Attach the handles and mark where the entry holes will be.
Step 3:
3. Mark where there will be exit holes for handles.
Step 4:
4. Then take the drill to the size of our handles. I have a handles 10 mm.
Step 5:
5.Stainless steel fully threaded stud 1m cut into 4 parts
Step 6:
6. Using a screwdriver, screw the stud into the holes
Step 7:
7, I marked the holes for the handles so that I could use the clamp with one hand
Step 8:
8. The grip force of the small clamp from the store.
Step 9:
9. The grip force of my clamp
Step 10:
Our clamp is ready. Thus it is possible to make clips and longer.
Hope you like my DIY.
Best whishes !
