Introduction: Homemade English Muffins
About: I enjoy crafting, photography, gardening and cooking. I am an avid cooking contester and I have won several national contests.
I grew up eating English muffins for breakfast! I always loved toasting them until the nooks and crannies became crispy and they held the butter and jelly in place! There are so many things you can make with English muffins including an egg and cheese sandwich or how about Eggs Benedict? They are also great as the bread for a cheeseburger or for any kind of sandwich. The possibilities are endless! Now I will show you how easy it can be to make them at home. I am happy to have you follow along with this Instructable!
Step 1: Ingredients Needed
1/4 cup nonfat dry milk
1 tablespoon granulated sugar
1 teaspoon kosher salt
2 cups plus 2 tablespoons unbleached flour
1 cup water
1 tablespoon plain yogurt
1 tablespoon butter
2 teaspoons active dry yeast
extra butter for greasing the rings
extra flour for dusting the rings
1 1/2 teaspoons yellow cornmeal
Step 2: Supplies
stand mixer or electric mixer
medium mixing bowl
spatula
rubber scraper
1 cup glass measuring cup
candy thermometer
spoon
4 baking rings
1/4 cup dry measure
griddle pan
1/4 sheet baking pan
plastic wrap
Step 3: Warm the Water
Place 1/4 cup of the water in a 1 cup glass measuring cup. Microwave at 100% power for 25 seconds. Check the temperature with a candy thermometer. It should read 110 to 115 degrees F. Continue microwaving at 15 second intervals until it reaches that temperature.
Water that is too hot will kill the yeast, but if it's too cold, the yeast won't be activated.
Step 4: Activate the Yeast
Add 2 teaspoons active dry yeast to the warm water and stir. Add 1/4 teaspoon of sugar and and 1/4 teaspoon flour.
Stir well. Let the yeast mixture rest for about five minutes. It should begin to foam.
Step 5: The Yeast Is Foamy
Now the yeast is foamy and ready to use.
Step 6: Start Mixing
Combine the dry milk, sugar, salt and flour in the bowl of the stand mixer.
Step 7: Melt the Butter
Place the butter in a small microwavable bowl. Microwave on 50% power for 40 seconds, or until melted.
Step 8: Add the Wet Ingredients
Add the melted butter, remaining 3/4 cup water, yogurt and proofed yeast mixture to the dry ingredients. Using the paddle attachment, set the stand mixer to medium low speed. Let it mix for 5 minutes.
Step 9: It's Mixed!
Here is how the dough will look. It is well blended and fairly loose.
Step 10: Place in a Bowl
Spoon and pour dough into a medium mixing bowl. Cover it with plastic wrap and leave it overnight to rise in the refrigerator.
Step 11: The Dough Has Risen!
The next morning, remove the bowl from the refrigerator. Take off the plastic wrap and you will find that the dough will be nice and puffy!
Step 12: Prepare the Rings
Generously grease the inside of the baking rings with butter.
Step 13: Now Flour
Lightly dust the rings with flour. Tap to remove any excess.
Step 14: Time to Butter
Generously butter the surface of the griddle pan.
Step 15: Add Cornmeal
Sprinkle the cornmeal over the butter on the griddle pan.
Step 16: Butter the Cup
Butter the inside of a 1/4 cup measure so that the dough will not stick.
Step 17: Set the Rings
Set prepared rings onto the griddle pan. Turn heat on the burner to low.
Step 18: Add the Dough
Using the buttered 1/4 cup measure, spoon dough into each of the 4 rings. This should use about half of the dough.
Step 19: Cover Up!
Place a baking sheet on top of the rings to cover.
Allow to cook on the first side for 6 to 10 minutes, depending on the temperature of your griddle.
You can check the bottom by picking up the edge with a spatula to check for doneness.
Step 20: Flip and Cook
Using the spatula, carefully flip each ring over. Cook on the second side for about 6 minutes until browned on the bottom. Be careful not to burn them.
Step 21: Time to Preheat
While the muffins cook on the second side, preheat the oven to 350 degrees F.
Step 22: Remove From Rings
Using the spatula, place the cooked muffins on a baking sheet. Carefully remove the muffins from the rings. If they stick, run a knife around the edge. Quickly press down each muffin with the spatula.
Step 23: Bake in the Oven
Place pan with the muffins in the oven. Bake for 5 minutes to make sure the muffins are fully cooked in the center.
Step 24: Repeat
There should be enough dough left to make 4 more English muffins. Repeat steps 17 to 23 with the remaining dough.
Step 25: Cool and Split
Allow English muffins to cool completely. Using a fork, split each muffin. Push the tines of the fork into the side of the muffin across the center. Rotate the muffin and push with the fork until the muffin splits. Fork splitting helps to make the nooks and crannies that we like to see. If you would prefer, you could cut it across with a knife instead of using the fork.
Step 26: They Are Finished!
And that is how you can easily make your own English muffins from scratch in your kitchen!
Step 27: Enjoy!
Toast each half in your toaster or toaster oven. Top each muffin any way you like. Pictured here I used lots of butter and grape jelly. Sit back and enjoy the crispy goodness of what you have made!!!
