Introduction: Homemade Flame Retardant
This is my first instructable, so please bear with me. Many times in the course of building / re-purposing items for various projects I have encountered a need to add some level of flame resistance to certain elements of the project.
While this procedure won't make any items flame proof, it will minimize the probability of ignition. In this tutorial I will offer a possible solution for flammability problems along with the recipe and the results from a quick and dirty experiment. This technique will only work for natural materials such as wood, cotton, jute, and paper or the like. It will not work for synthetic materials such as polyester, nylon, polypropylene or anything else that did not originally come from a plant or tree.
Step 1: What You Will Need
Borax (sodium borate) laundry booster
A measuring cup
A 1 Tablespoon measuring spoon
An old sauce pan
A storage container
Some sort of applicator ( paint brush, spray bottle, etc)
Step 2: Procedure
You want to make a saturated solution
Boil 1 cup of water
Add 2.5 tablespoons of Borax to the boiling water
Stir until the Borax dissolves
Allow to cool to room temperature. Some of the Borax will precipitate out as the solution cools. This is normal, the clear liquor left is the flame retardant mixture.
Pour the clear liquid into storage container or spray bottle.
Step 3: Application
You can use a spray bottle or brush
Wet the heck out of the item to be protected. Make sure it is saturated.
If you run out of solution, make more, because the item has to be absolutely positively soaked.
When you think its wet enough, wet it some more
Allow to dry
Once the solution dries, it is very important to keep it dry as any water contact will wash the protection off.
Step 4: Experiment to Verify Effectiveness
Experimental Design:
Two 11” x 1” wide strips of printer paper were cut. One strip was soaked in the flame retardant (FR) solution for 5 minutes to ensure total saturation of the paper fibers. The other strip was used as an untreated control. The treated sample was removed from the solution and hung up to dry overnight. The untreated control was kept in close proximity to the treated sample to ensure that both samples were exposed to the same environment and that the only difference was the Borax treatment.
After drying overnight, the treated sample was cut into 3 roughly equal sections and the control was treated in the same manner.
Each specimen was then gripped in along handled pair of needle nosed pliers and lit with a match.
In every case the untreated specimens were completely consumed by the flame while the treated specimens smoked, generated a char and then self extinguished (right 3 specimens). Below is an image of the final results. In this image, I was only able to transfer the ash of one untreated control sample ((left side of the image) to the cardboard for the photograph, the other two controls disintegrated.
This works because the borax forms a primitive form of glass as it is exposed to the heat of the flame. The glass acts as an insulator, protecting the paper fibers from the heat and allowing them to char instead of burn. The char acts as an additional insulator. Eventually there is not enough heat to support combustion and the fire goes out.
Step 5: Final Comments
This will only work for natural materials, synthetics will not form a char, they will burn, melt and drip and set other things on fire. Once the solution is applied and dried it is important to keep the protected item dry or the protection will wash off. While I have used this method successfully in projects as varied as shop bullet traps to paper decorations, your mileage may vary.
Please do not use this info as a substitute for common sense.
28 Comments
Question 1 year ago
Really cool! Do you think this would work well with cardboard?
Answer 1 year ago
It should work with cardboard but I haven't actually tried it. Feel free to experiment and post your results! Good luck
5 years ago
Just great!...Can this be used on wood?, is there someting you can add or finish off that will make the product stick or adhere better or permanently?
Reply 5 years ago
Yes it can be used on wood. It should soak in somewhat. I am not aware of any finish but you may be able to add it to a waterbased paint,
Reply 1 year ago
I'm going to try adding the solution to my wood treatment for my new shed. Obviously the wood treatment will be water based. Anyone tried this before? Or see any problems, please?
Reply 5 years ago
It should soak into wood, but would likely take a good bit.
7 years ago on Introduction
"(B4O5(OH)4)2-" Boiled In "H2O" Re-Solidifies Too Quick & Clogs Orifices...
GIVEN:
1. My Borax re-solidifies when it begins cooling and that clogs my stuff, dude!
2. At 160F, I observed the Borax began to separate from the clear water slightly.
3. At 110F, I observed the Borax separate almost completely and pile up.
QUESTION 1: Should I boil for longer?
FYI, I boiled it a second round for 7 minutes: it still re-solidifies around 110F.
QUESTION 2: Will adjusting the pH have the effect of lowering the working temperature to a magnitude that won't melt my spray bottles and allow the borax to flow past the tiny pump mechanisms and the orifice?
QUESTION 3: Is there anything besides water (such as rubbing alcohol or mineral spirits) that will work better and not interact with #1 and #2 plastic spray bottles?
Reply 1 year ago
I believe you would allow the mixture to cool and *excess* Borax/ Boric Acid to precipitate out. The remaining liquid is a saturated as as it can be at your local field conditions.
Alternatives I have seen elsewhere include PropyleneGlycol and EthyleneGlycol which (apparently) will also act as a transport for the Borax ... depends on what your using it for.
I have used the Rosco products many times and they work well.
They also save a heap of paper work and clipboard grief.
Question 4 years ago on Introduction
Would this work on Crayola Air dry clay?
4 years ago
Borax has excellent solubility in water. It is used as a laundry chemical - it wouldn't work at all if it had poor solubility.
4 years ago
Borax has very poor solubility in water, Borax and Boric acid together are water soluble,this mix will work much better. Try 4 parts Borax to 3 parts Boric acid.
5 years ago
Tim Hargreaves - Shark Bay, WA Pastor also known as Hargreaves the Handyman.
Well done mate - I don't know the chemical make-uo of Borax but if as I suspect there is a salt factor then SALT is a good fire inhihitor. The Tamarisk tree sheds a high quantity of salty resin & trying to burn the needles it sheds is extraordinarily difficult just as is the case with seaweed.
Repetitive spraying of palm fronded partition walls - as likewise any other flammable material - with plain old sea water is a cheap way to help with fire-proofing materials. This of course is against the initial fire risk of a casual flame. At the end of the day almost NOTHING can withstand fire in its extreme expression such as an oxyacetylene flame or a roaring bush fire..
5 years ago
Thanks very much for this.
We're in the earliest stages of making papier mache ceiling tiles for our home, and this will allay a few concerns.
Reply 5 years ago
It should work well with papier mache. Are you planning ti add it to the mix or treat the tiles after they are finished? Thanks for the kind words
Reply 5 years ago
I'm on the fence about that- the spray approach would be less iffy to the formula, I'm thinking, but also less convenient/ thorough. We're still experimenting with our goop formula, although we're doing a first "final" tile today. Thinking I'll add it to the "goop" at the tail end of the cooking process, today, just before running it through the chopper to make it into "clay" [and adding the dyes]. I"ll share photos later if you like.
5 years ago
Wow, just read through the procedure and comments. KUDOS to you folks all around. I am a forensic science teacher in Modesto, and we are using your formula and method to have the students investigate the recent Ghost Ship fire. Specifically, after examining the facts so far in the far over five sources, and answer the standard "who, what, etc for all, then compounding retardants to see if this process would have provided a measure of protection for the inhabitants (not encouraging the apparent failure on several parties and levels to provide common sense hazard mitigation). Thank you for posting folks!
Reply 5 years ago
Thanks, I'm glad it is useful
Reply 5 years ago
Excellent! Thank you!
6 years ago
FYI...when I applied this to our curtains at our school and the fire inspector showed up, he said that this was not acceptable unless it was tested by a laboratory with a copy of the test report. So, I wound up purchasing a fire retardant called Flamex PF which worked better than this formula and was accepted for code.
Reply 6 years ago
Good to know. Thanks for letting the community know. In general it is a good idea to use 3rd party certified products when in a public environments.
Brominated flame retardants are very effective. The Flamex PF you mention uses ammonium bromide instead of Borax.
