Introduction: Homemade Gas Welding Torch
This is how you can easily make a super & simple gas welding torch with a few household material. This is just an homemade idea so that you can learn how the gas welding actually works.
Material Used:
- Water bottle
- Syringe pipe
- Calcium carbide(CaC2)
Tools Used:
- Drilling machine
- Glue gun
Step 1: Drill the Bottle Cap
Make a suitable hole in the bottle cap enough to join it with the syringe pipe.
Step 2: Connect the Syringe End With Bottle Cap
The syringe pipe is the medium to transfer the acetylene gas which is going to be produced inside the bottle by some chemical reaction.
Step 3: Apply Hot Glue
Hot glue is applied to the inner and outer side of bottle cap to make it airtight.
Step 4: Fill the Bottle With Calcium Carbide
Take an small amount of Calcium carbide(CaC2). Normally It looks like stone which is stored in moisture free area.
Step 5: Pour Some Water
Water reacts with calcium carbide and release inflammable acetylene gas. Be careful while mixing the calcium carbide with water because the process releases an small amount of heat.
Step 6: Ignite the Torch
Finally ignite the torch with lighter.
Step 7: Video
Watch the video for detailed description of each step.
