Introduction: Homemade Graham Crackers
Graham crackers are easy to make and delicious, though they do take a little time. They're great for snacking or making pie crusts, and can be dipped in chocolate or used in other recipes as well (like S'more Candy Bars - YUM).
Step 1: You'll Need. . .
Software:
- 2 cups all purpose flour
- 1/2 cup spelt flour (can be substituted for whole wheat or all purpose flour)
- 1 cup dark brown sugar
- 1/2 teaspoon baking soda
- 3/4 teaspoon salt
- 7 tablespoons unsalted butter (cold)
- 1/3 cup mild tasting honey (clover honey works well)
- 5 tablespoons milk
- 2 tablespoons pure vanilla extract
- additional flour for rolling
- (optional) for topping: 3 tablespoons white sugar and 1 teaspoon cinnamon
- large mixing bowl and your hands (can use food processor)
- measuring cups and spoons
- plastic wrap
- rolling pin
- baking sheets lined with silicone baking mats or parchment paper
- a board scraper/pizza cutter/sharp knife (I like to use a board scraper that has a sharp edge and ruler along the side like this one)
- fork/toothpick/bamboo skewer
- ruler (optional)
- cookie cutters (optional)
Step 2: Measure and Mix
- Add flour, spelt flour, brown sugar, baking soda and salt to bowl and mix to combine well
- Add butter and mix well using fingers (or pastry cutter or food processor). The mixture should resemble coarse meal
- Combine milk, honey, and vanilla extract
- Add to flour and butter mixture and mix with fingers (or food processor) until just combined
- Lay out a sheet of plastic wrap and dust it with flour
- Turn dough out onto the plastic wrap and form into a square approximately an inch thick
- Dust the top of the dough with flour and wrap in the plastic
- Refrigerate for at least 2 hours
Step 3: Rolling and Forming
- Divide the dough in half and return half to the fridge
- Dust the work surface and rolling pin with flour and roll the dough approximately 1/8 inch thick
- Measure and cut your crackers to the desired shape and size with the board scraper/knife/pizza cutter. If you're making S'more Candy Bars you can measure the size of your mold and make a graham cracker slightly smaller than the mold so that it will fit perfectly. You can also use cookie cutters to cut fun shape, or you can press dough in a thin layer of a small spring form pan to make a crust for a mini-cheesecake
- Place the crackers on baking sheets lined with parchment or silicone baking liners and dust with the cinnamon sugar topping (if using - I skipped this step for these)
- Chill until firm (approximately 30-45 minutes in the fridge or 15-20 in the freezer)
- Any scraps can be gathered together and re-rolled the same way
- Repeat with second half of dough
Step 4: Finally Time to Bake
- Preheat oven to 350 degrees Fahrenheit
- Using a fork/skewer/toothpick, poke holes in the crackers (this is mostly decorative and can be skipped if desired)
- Bake for 15 to 25 minutes, rotating sheets halfway through baking. Baking time will depend on your oven, but the crackers should be slightly firm and browned when done
- Allow to cool and enjoy as is or use in your favorite recipes!
