Introduction: Homemade Jewelry
This instructable will teach you a fun and easy way to make home made jewelry. We will be creating a matching set of earrings and necklace. Not only is this an enjoyable activity but your creations can be given as gifts. This easy activity could also be utilized as a fun party craft. I aspire that this instuctable will inspire you create your own home made jewelry.
Step 1: Materials
-2 inch headings
-Fishhook Earrings
-Beads
-String or Chain
-Needle-nose Pliers
Step 2: Step 1- Earrings
-Cut 2 headings to half an inch
-Add one bead to each heading
-Bend headings to create a loop
Step 3: Step 2- Earrings
-Add fishhook earrings to loop
-Pitch loop to secure earring
Step 4: Step 3- Earrings
-Cut 6 headings to 3/4 of an inch each
-Add a bead to each heading
-Use needle-nose pliers to create loose loop at the end of the heading
Step 5: Step 4- Finalize Earrings
-Add one heading by pitching the loop above the previous bead
-Then repeat this until you get the length you desire
Step 6: Necklace
-Cut 1 heading half an inch
-Cut 1 heading one inch
-Then cut 4 headings to 1 1/4 an inch
-Create a loop with needle-nose pliers at the end of each heading
-Use the 1/2 heading with the bead as the staring
-Add a 1 1/4 heading by pitching the loop above the bead
-Repeat this for then next three
-Then add the one inch heading with bead by attaching to loop to finalize
-Then for the final touch find a string or chain to finish the necklace
