Introduction: How to Make a "MAD MANTIS" Weedeater Cultivator
Step 1: Used Weedeater
I have had this weed eater for several years now .Been very reliable and is expensive one at that too. Its a stihl 26 cc straight shaft for bush whackin attachments .
Step 2: Tiller Attachment
This is the tiller attachment for my 4 stroke troybilt weed eater that didnt get used because of bending over so far to get it to work properly.
Step 3: Disassembling
I unscrewed the motor and the handle bars from the straight shaft weed eater
Step 4: Putting Things Together
I simply put the weedeater motor on the tiller attachment until it bottomed out on the shaft. Then tightened up the screw.
Step 5: Making the Frame
I cut 2 pieces of 5/8 black iron pipe 4 feet long
Step 6: Drilling
I measured 4 holes to match the bolt holes on top of the tiller attachment . Drilled 4 1/4 inch holes.
Step 7: Frame Assembly
I bolted the bars on the top of the tiller attachment.
Step 8: Bending the Frame
I measured 6 inches back from the end of the pipe and made a cut on each bar so i could bend the pipe until it came up against the back of the motor, and then welded the cuts back together.
Step 9: Frame Brace
I drilled 2 1/4 inch holes through the pipe and into the back of the motor frame .Careful not to drill through the fuel tank. and bolted it together for stability.
Step 10: Handle Bar Bracket
I welded a piece of inch and a half square tubing on top of the two ends of tubing.Then welded a 1 inch nipple on top.
Step 11: Adjusting the Handle Bars.
I fitted the handle bars for comfort and there ya go . A mantis is about 3 to 4 hundred dollars . I built this for under 25 dollars. And the best part is ,when i m done with it and i want to switch it back to the expensive weedeater i can with no problems.
Here is a link on youtube to watch it in action.. http://www.youtube.com/watch?v=yPnwbMImxKU
38 Comments
9 years ago on Introduction
now i know what im gonna use in a zombie apocalypse :D
lol
10 years ago on Introduction
I used my Tiller again this year .Also my friend used it too because his broke!!!!!
I'm going to have to look for one of these attachments for one of my trimmers. I recently acquired an FS-108 but it didn't come with a head, so I had to steal the head off my FS-55 which leaves me down a head now.
12 years ago on Introduction
Looks dangerous to all displeasing weeds everywhere! How does it fair in deep soil?
Reply 12 years ago on Introduction
Works great. For some reason the way its made .it tills up deeper when you pull backwards . It really digs then..
Exactly what I joined Instructables for! Good job. (yeah, I know this is a year later - 'ibles is timeless)
I had the same problem with my Masport cultivator, so mostly used it by pulling it backwards. I think both you and I are forcing our cultivators to be rotaryhoes. Cultivators are designed to "fluff-up" the top layer of loose soil and scuff up weeds and are often not self-driven, so their tines rotate forward to pull them along the ground - this makes them climb out of the soil if it's too hard. Rotaryhoes are for breaking up soil and are usually self-propelled with the tines working against the direction of travel - this makes them dig in, which is why they have a depth limiter. Having said that, I've done a lot of hoeing with my cultivator! Either way, your idea is brilliant.
The first picture below shows me "rotaryhoeing" by pulling backwards. Long handles like yours would certainly help! The second pic shows the handtool eqivalent of a cultivator (in my hands) vs a rotaryhoe (the steelshafted garden fork on the very left of the pic). Can the cultivator do the fork's job? With a lot of effort, but basically no. Can the fork do the cultivator's job? Well sort of, but basically no. Right tool for the right job. If I was to break up a lot of firm ground, I'd hire a proper rotaryhoe.
Thanks for the comment . I knew that when you go forwards it just skims the surface and and when you go backwards it digs in . Which i think is ok. when i get a chance im going to try and turn the head around and see if it digs in going forwards and skims going backwards ..
Reply 11 years ago on Introduction
when you walk forwards it just grinds the surface but when u back up . it digs about 6 inches down automatically. works very well .I have alot of compliments from the neighbors lol
Great idea but anyone come up with making a "wheeled weed whacker". I am on the verge of buying one and price runs from 200 to 400. I never thought of taking a straight shaft weed eater, maybe one can shorten the length of the shaft (?) and mount it on some wheels. Ryobi has one for 200 but with a curved shaft which I don't like. So a modification to this for wheeled weed wacking might work. I will post it here if I get the idea ironed out. Contact me if you have suggestions.
I actually thought about taking a regular push mower and taking the blade off and using the assembly from a weedeater and mounting it on the front of the push mower ... hhhhmmmmmmmmm
I was going to try and make a small outboard motor for my kayak out of an old weed whacker, any tips?
that depends on how you plan on mounting it to the kayak.
Guess I don't follow the excitement. Ryobi has been selling a weed whacker for years which has a removable head, and you can substitute attachments, such as a tiller, edger, and etc. I have all the attachments, which run $40-60 each, plus the basic machine for around $90. The attachments will fit a variety of weed whackers sold under differenct names.
A heck of a lot easier than building one, I must say.
Ok Reddnekk
I will try and explain it to you again .Did you actually read the instructable? I have the same kind of weed eater ,except its not a ryobi. I bought the tiller attachment for it for 60.00. This instructable happened because when i used the weed eater with the attachment it hurt my back after about 5 minutes. I had another weed eater that i just took the head and handle bars off and made a different frame . Now i can use the attachment with ease...
Building things is fun mate. Plus, 40$ is a lot of money
nice job, didn't buy that attachment for that very reason. awesome. 4/5
good effort
The attachment that I have isn't straight it has a curve, is there anyway I can make something similar to yours?
Well that lil stinker really makes short work of the weeds! Excellent job!
