Homemade Oil/Air Pump From Car Parts
Intro: Homemade Oil/Air Pump From Car Parts
This is a homemade Oil/aAir pump I originally made for my foundry to pump oil but then later just use it to air up my tires around the house.
It work great and airs tires up very quick and it's not loud at all.
I just used an old ac pump off a truck I scrapped and a 3/4 motor I had also off an old furnace.
I had a metal box that was a printer switch box and some cheap parts from radio shack.
Now I used my homemade plasma cutter and cut the top off an old air compressor to use as a plateform but you can just use a 2x6 or 2x12 or just any kind of wood you want according to your scrape pile.
I welded to my base but if you use wood just use some bolts and washers.
Hope you enjoy and have fun.
Want to see more check my other instructable like homemade plasma cutter and Jacobs ladder.
Also my web site http://theplasmacutterman.com/.
P.S. check out my Tesla Levitating Steam Punk Lamp on You Tube.
STEP 1: Instructions and Parts Needed
Here are your parts your gonna need and how I done it.
I also through in a couple of pictures I made before I built it to give me an idea of how I was to do it.
This is a Word document file with instructions and parts needed.
STEP 2: 12 Volt Clutch Supply
You can get all these parts from radio shack or some old electronic equipment like an old treadmill.
STEP 3: Finnish Up and View
They are very clear and easy to see how I made mine and you wont have any trouble.
I put all pictures and info in this step so you wont have to keep flipping back and fourth to study everything.
So it's all here for ya.
Have fun and enjoy.
10 Comments
aideym 12 years ago
thanks and great instructable
Plasanator 5 years ago
An ac system has oil in it that goes through system.
The pump always holds enough oil to keep it lubricated.
now using for air pump or vacuum pump every once in a while add a little to it, if you over fill it it will pump out extra oil, wont hurt tires for some to get in them.
chebhou 8 years ago
does the compressor got damaged for the lack of lubricant when it pumps air only ?
Plasanator 6 years ago
no because I add a few drops every so often and its still kicking.
It will always have a little inside unless you just run it for hours at a time, but for air tank, tires filling floating toys for pool its great.
Also I use it to vacuum down car ac when it needs a charge.
Plasanator 8 years ago
Nope, I only use it to fill air tank or tires.
About once a year I let it suck up an oz or 2 just to keep it lubricated well.
Without it being a closed system the internals stay lubricated for a long time.
abadfart 8 years ago
It looks like you used a York compressor like were used in lots of vehicles from the 70s to the 80s. They are known as the king of onboard air by the off road I g community that install them to air up tires. The large ones put out about 9cfm and they are alloild by a internal oil reservoir instead of being lubricated by the freon.
crazy man custom cycles 10 years ago
Plasanator 12 years ago
ralugo5 12 years ago
DriX 12 years ago
Cheers.
