Homemade Pop Pop Crackers
8,591
35
Introduction: Homemade Pop Pop Crackers
About: I am New Pew, I create electronic projects and share these creations on my YouTube channel. In every video I mainly show how you can make these innovative creations yourself! There is a description of each pro…
In this Instructable, I'll show you how to make your own Pop Pop Crackers. On the internet I came across several projects in which they make pop pop crackers but it didn't seem to work or they used materials that not everyone has at home.
The idea of using matches has come up before. These were then wrapped in paper with a little scraping off the striking surface. I tried to make these but they did not work or hardly worked, there was simply not enough mass. By adding small pieces of stone I managed to create more mass so that the Pop Pop Crackers now work well.
The match head is typically composed of 45-55% potassium chlorate with a little sulfur and starch. The safety matches ignite at striking surface due to the extreme reactivity of red phosphorous with potassium chlorate. Instead of striking it manually, the friction in the pop pop crackers is created by the force released when they hit the ground.
Video Tutorial
Materials:
  • Matches (including box)
  • Small pieces of stone
  • Scrap paper
Tools:
  • Hobby knife
  • Pliers
Step 1: Take the Heads Off
Start by removing the heads from the matches with the pliers. By squeezing them a little, they break and fall off into pieces. Collect the pieces in the matchbox.
Step 2: Striking Surface
Now take the outer box of the matches and a hobby knife (another sharp knife will probably do too). Gently scrape off small pieces of the striking surface. Also collect these pieces in the container.
Step 3: Stones
Now take the small stones and add them to the mixture from steps 1 and 2. Take care not to add too many stones. 3 or 4 small stones per cracker should be sufficient. When the stones have been added, mix well once.
Step 4: ​Make the Crackers
Get a piece of scrap paper (about 5 by 5 centimetres). Add a little bit of the prepared mixture.Fold the scrap paper around the mixture. Then roll the paper to a point to seal it.
Step 5: Ready!
The Pop Pop Crackers are ready!
Of course only use outdoors!
Video tutorial:
Have fun with the Pop Pop Crackers, stay healthy and see you soon!
New Pew
Be the First to Share
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    2 Comments
    holsen1
    holsen1
    2 years ago
    WHAT
    ZexetorM
    ZexetorM
    2 years ago
    brilliant!
