Introduction: Homemade Rc Airboat Explorer With Fpv
check out my projet
Step 1: Introduction
hello, I present you my airboat.
I was looking for a way to explore the rivers without the propeller that stuck in the grass ect .... I am a fan of FPV so I have to integrate it. then to explore well I need a long range and a good quality video that I could record. I managed to do it !! and I get excited to make it evolve in any medium possible
here is how to realize it!
Step 2: MATERIAL AND INSTRUCTION
the material for the chassis is a 6mm foam plate and hot glue.
raw the different pieces on the plate of the measurements depends on your project but for a good stability I advise you not to exceed 40cm X 20cm, cut them cleanly with a cutter (new blade !!)
stick the pieces between her with hot glue (which also plays the role of tightness) do not hesitate to put a lot!
for fixing the engine and the governor I print (with the printer that I built myself!)
a great thing find on thingiverse.
https://www.thingiverse.com/thing:2388826
https://www.thingiverse.com/thing:1851948
for a good seal of the electronic system I use a box that I recovered after eating what was in it!
moteur
https://www.banggood.com/fr/Racerstar-2838-Sensorl...
servo pour la direction https://www.banggood.com/fr/K-Power-P0090-9g-Micr...
transmeteur fpv https://www.banggood.com/fr/Eachine-Racer-250-Dro...
antenne https://www.banggood.com/fr/Eachine-Racer-250-Dro...
otg https://www.banggood.com/fr/Eachine-ROTG02-UVC-OT...
camera mais sans le transmeteur qui a griller !! https://www.banggood.com/fr/Eachine-TX02-Super-Mi...
batterie https://www.banggood.com/fr/ZOP-Power-7_4V-1500mA...
transmetteur (modifier en 9xr ) https://www.banggood.com/fr/Wholesale-FlySky-Upgr...
for the engine I chose model for car to be able to have a reverse
I did a test with a 2204 2300KV drone engine and it works great, but without going back)
for the governor a servo 9g does the job well.
for the command I use my flysky fs th9x to modify with companion 9X in 9XR (any radio control 2 way does the trick)
for the fpv I use a camera eachine tx02 and a transmitter 600mw taken on my old drone racer 250
after several tests I installed counterweight weight in the back because, at full speed, it sank into the water from the front.
now it is perfect, no problem and a lot of fun !!
