Homemade Sunscreen
Intro: Homemade Sunscreen
Make your own sunscreen with this easy recipe.
Sunscreen is intended to shield your skin from harmful UVA and UVB rays. These can cause premature aging, and more tragically, skin cancer. But commercial suncreens often involve more nasty chemicals than necessary.
By making your own sunscreen, you control exactly what goes in!
In response to a lot feedback I've been getting on this Instructabe, I decided to offerr an all natural TD/ZO alternative. Check it out here!
STEP 1: Materials
Essential Ingredients
UPDATE:
Tools:
Scoochmaroo is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com.
- 8oz carrier. oil - jojoba, grapeseed, or almond are my preferences
- 1oz emulsifing wax
- Sunblocking agent - micronized zinc oxide or titanium dioxide.
- Essential oils - coconut is classic
UPDATE:
I recently discovered this great combination of zinc + micronized titanium dioxide. I consider it to be a safer alternative, as it contains no nanoparticles, and can be used on its own as a powder sunblock! I don't however have a chart for how the SPF is effected when combining with lotions or other carriers.
Tools:
- Mixer - either handheld mixer,immersion blender, or mini chopper - NOT TO BE USED FOR FOOD AFTERWARDS
- Silicone spatula
- Disposable pastry bag or plastic baggie
- Container for your lotion
- Scale for accurate measuring
- Gloves and an approved safety mask for handling powdered agents
STEP 2: An Easier Recipe
If you want your sunscreen NOW, and you don't want to mess around with making your own lotion, just buy your favorite lotion from the store, and add your zinc oxide and titanium dioxide to that!
This means you can make sunscreen that's sensitive enough to use on delicate skin, or is already your favorite scent or creaminess.
- 8oz lotion - my new favorite, CeraVe has been recommended to me by several dermatologists!
- Sunblocking agent - micronized zinc oxide or titanium dioxide - follow chart below for appropriate portions, and following the remaining directions ORZinc oxide + titanium dioxide powder
- Container
STEP 3: Mix Oils and Wax
Measure one ounce of wax into a microwave safe container.
Melt on high heat (approx 1 minute for me).
Add 8oz. oil, and blend well.
Add a few drops of essential oils for scent.
The mixture may need to back in the microwave for a bit if it starts to harden up again.
STEP 4: SPF Table
If using the zinc oxide or titanium dioxide separately, use the following table to determine your measurements.
I don't have a chart for using the blended powder, but it starts off with SPF35 on its own.
For example, 8oz. (weighed) of lotion + .8oz of titanium micronized dioxide (weighed) = SPF20+
The Micronized TD is 10% of the original amount of lotion used (not the finished weight).
If you used 8oz of lotion + .8oz of Micronized ZO, the SPF would be 11-12.
If it's still too confusing, ask!
Concentration of
Sunscreens & SPFLow
(SPF 2-5) Moderate
(SPF 6-11) High
(SPF 12-19) Ultra High
(SPF >20) Titanium Dioxide <4 % 8 % 12 % 20 % Titanium Dioxide, Micronized 2 % 4 % 6 % 10 % Zinc Oxide 5 % 10 % 15 % 25 % Zinc Oxide, Micronized 3 % 7.5 % 12 % 20 %
This chart is to provided by my supplier. I can not do any testing internally. Just to be used as a guideline.
Concentration of
Sunscreens & SPFLow
(SPF 2-5) Moderate
(SPF 6-11) High
STEP 5: Add Dry Ingredients
Wearing your gloves and mask, carefully measure zinc oxide or titanium oxide into your blending container (see chart above).
For this recipe, I weighed out .9oz of Micronized TO to make an SPF >20.
Add the wax/oil mixture to the powder.
Blend thoroughly.
Scrape the sides of your mixing bowl and blend some more.
Continue blending until the powder is thoroughly incorporated.
Blend thoroughly.
STEP 6: Transfer Into Container
Use a silicone spatula to transfer your mixture into a pastry bag or plastic baggie with the corner snipped off.
Squeeze the lotion into your new containers and label.
Apply liberally and frequently!!
STEP 7: Disclaimer
These recipes and instructions are for homemade use only.
The concentration of TD/ZO in the lotion is approximated for ease of use. The variations in concentration will still fall within the SPF ranges set forth, and should not cause concern in small batches (approx 8-12oz)
If you want to make and sell a skin care product, you must adhere to the regulations set forth by the location where you conduct your business.
Be aware of the shelf life of products made without preservatives.
The beauty (and simplicity) of making your own product is that you don't have to adhere to the stringent industry guidelines of manufacturing to lengthen the shelf life. Simply make enough to be used within a short period of time.
Click here for wabisabibaby's shelf-life article on what to do to make lotions last about 3 months.
thank you to wabisabibaby for setting forth and inspiring this disclaimer, and for an awesome lotion instructable.
131 Comments
brenda.susimierzejewski 9 years ago
Hello! If my batch of lip balm weighs 64 ounces, how much zinc oxide would I need to add to get an spf of 20? Is their a formula I can use to calculate this? I see I would need 25% zinc to get spa 20 but what is the calculation? Thanks
JenniC1 8 years ago
Hey Brenda, did you ever figure this out? I'm trying to make an SPF lip balm and am struggling with finding a formula
elizabetha9 8 years ago
Hi--i'm not the author, but in making sunscreen, you calculate by weight. Usually they say that 20% zinc = SPF 20, so you would use a food scale and add ~13 oz by weight of zinc to 64 oz by weight of balm!
JenniC1 8 years ago
Much appreciated! Now I feel confident I can make this :) thanks!
hobhob 8 years ago
"manufacturers have to respect the 25% limit (of titanium dioxide nanoparticles) according to European legislation". (Micronized TD is 15 nanometers in particle size; it is considered a "nano" particle)
JenniC1 8 years ago
This is an awesome informational tutorial however the lack of response from the author is quite sad . Might as well disabled comments if you'll never reply to any questions from your readers.
manicmonday 8 years ago
So, sounds like your saying use lotion to zinc oxide 4 to 1 would make spf-20, right?
MaryAnnM1 8 years ago
ambiguator 9 years ago
I'm about to put in an amazon order for the ingredients I need, but I'm wondering about the thickness of this stuff. Does the beeswax thicken it up enough that it won't turn into straight liquid on a hot sunny day? I'm looking for lotion consistency, not tanning oil consistency.
Thanks for the recipe!
HrdWodFlor 9 years ago
With my experence with homemade lotions, this will get thinner as it heats up. you can always melt it back down and add more beeswax to get a thicker product on hot days.
pamela.l.moore 9 years ago
If I use 2 cups of olive oil, 1 cup of coconut oil, 1 cup of beeswax then how much zinc oxide do I use . I used 8 tbsps. . is this too much?
CristinaD 9 years ago
I purchased a mineral sunscreen what lists 8% TiO2 as the only active ingredient and the product is labeled spf 25.. why?
charlieanderin 9 years ago
tsbeanie 10 years ago
we have lots of coconut in the area, and can easily extract coconut oil. Can I use it as base/carrier?
jagirl 10 years ago
I made it. was so white on the skin.. Gonna try again using less zinc
Ramireex 10 years ago
Kisu Usagi 11 years ago
I also wanted to point out that in my research I've found that powder screens are somewhat dangerous because of the likelihood of inhalation. I originally planed to make a powder because it seemed easier and I hate the feeling of putting on greasy sunscreen in the middle of summer but have decided against that because of this health risk.
Thanks for your time, eagerly awaiting a reply :)
shazni 11 years ago
LesB 11 years ago
I'm an endurance cyclist and will sometimes be on the bike from sunrise to sunset, and I won't touch any sunscreen other than zinc/titanium combos. BTW, one of those ingredients is better for UVA, and the other is better for UVB, but I don't remember which is which. Here's more info:
http://www.oleda.com/oleda_tips/tips.asp?dept=134
shazni 11 years ago
