Introduction: Homemade Sunscreen
Make your own sunscreen with this easy recipe.
Sunscreen is intended to shield your skin from harmful UVA and UVB rays. These can cause premature aging, and more tragically, skin cancer. But commercial suncreens often involve more nasty chemicals than necessary.
By making your own sunscreen, you control exactly what goes in!
In response to a lot feedback I've been getting on this Instructabe, I decided to offerr an all natural TD/ZO alternative. Check it out here!
Step 1: Materials
Essential Ingredients
UPDATE:
Tools:
Scoochmaroo is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com.
- 8oz carrier. oil - jojoba, grapeseed, or almond are my preferences
- 1oz emulsifing wax
- Sunblocking agent - micronized zinc oxide or titanium dioxide.
- Essential oils - coconut is classic
UPDATE:
I recently discovered this great combination of zinc + micronized titanium dioxide. I consider it to be a safer alternative, as it contains no nanoparticles, and can be used on its own as a powder sunblock! I don't however have a chart for how the SPF is effected when combining with lotions or other carriers.
Tools:
- Mixer - either handheld mixer,immersion blender, or mini chopper - NOT TO BE USED FOR FOOD AFTERWARDS
- Silicone spatula
- Disposable pastry bag or plastic baggie
- Container for your lotion
- Scale for accurate measuring
- Gloves and an approved safety mask for handling powdered agents
Step 2: An Easier Recipe
If you want your sunscreen NOW, and you don't want to mess around with making your own lotion, just buy your favorite lotion from the store, and add your zinc oxide and titanium dioxide to that!
This means you can make sunscreen that's sensitive enough to use on delicate skin, or is already your favorite scent or creaminess.
- 8oz lotion - my new favorite, CeraVe has been recommended to me by several dermatologists!
- Sunblocking agent - micronized zinc oxide or titanium dioxide - follow chart below for appropriate portions, and following the remaining directions OR Zinc oxide + titanium dioxide powder
- Container
Step 3: Mix Oils and Wax
Measure one ounce of wax into a microwave safe container.
Melt on high heat (approx 1 minute for me).
Add 8oz. oil, and blend well.
Add a few drops of essential oils for scent.
The mixture may need to back in the microwave for a bit if it starts to harden up again.
Step 4: SPF Table
If using the zinc oxide or titanium dioxide separately, use the following table to determine your measurements.
I don't have a chart for using the blended powder, but it starts off with SPF35 on its own.
For example, 8oz. (weighed) of lotion + .8oz of titanium micronized dioxide (weighed) = SPF20+
The Micronized TD is 10% of the original amount of lotion used (not the finished weight).
If you used 8oz of lotion + .8oz of Micronized ZO, the SPF would be 11-12.
If it's still too confusing, ask!
This chart is to provided by my supplier. I can not do any testing internally. Just to be used as a guideline.
Sunscreens & SPF | Low | Moderate | High | Ultra High |
<4 % | 8 % | 12 % | 20 % | |
2 % | 4 % | 6 % | 10 % | |
5 % | 10 % | 15 % | 25 % | |
3 % | 7.5 % | 12 % | 20 % |
Step 5: Add Dry Ingredients
Wearing your gloves and mask, carefully measure zinc oxide or titanium oxide into your blending container (see chart above).
For this recipe, I weighed out .9oz of Micronized TO to make an SPF >20.
Add the wax/oil mixture to the powder.
Blend thoroughly.
Scrape the sides of your mixing bowl and blend some more.
Continue blending until the powder is thoroughly incorporated.
Blend thoroughly.
Step 6: Transfer Into Container
Use a silicone spatula to transfer your mixture into a pastry bag or plastic baggie with the corner snipped off.
Squeeze the lotion into your new containers and label.
Apply liberally and frequently!!
Step 7: Disclaimer
These recipes and instructions are for homemade use only.
The concentration of TD/ZO in the lotion is approximated for ease of use. The variations in concentration will still fall within the SPF ranges set forth, and should not cause concern in small batches (approx 8-12oz)
If you want to make and sell a skin care product, you must adhere to the regulations set forth by the location where you conduct your business.
Be aware of the shelf life of products made without preservatives.
The beauty (and simplicity) of making your own product is that you don't have to adhere to the stringent industry guidelines of manufacturing to lengthen the shelf life. Simply make enough to be used within a short period of time.
Click here for wabisabibaby's shelf-life article on what to do to make lotions last about 3 months.
thank you to wabisabibaby for setting forth and inspiring this disclaimer, and for an awesome lotion instructable.
