Introduction: Homemade Taser
These are the supplies that you will need to make a Homemade Taser. The first supply needed is a disposable camera.The second supply needed is 2 colored paper clips. The last supply is 1 double A battery.
Step 1: 1 Steps
The frist step in this process is to take the disposable camera apart and find the Kodak MAX Flash Unit.Which is the green thing in the camera like the picture below.
Step 2: 2 Step
The second step is to find the capasotater and then attach the 2 paper clips to it. Make sure you peel a little of the rubber off of both ends of the paper clips. Then attach them to the copasator and make sure they arn't touching at either end.Which is the big black thing at the bottom of the picture below.
Step 3: 3 Step
On the side of the capastor there is a spot for the battery. That is where you put the AA battery.
Step 4: The Last Step
The last step is to press the Si button on the bottom of the copasator and hold for 2 seconds. After you have done that press the 2 paper clip ends together and it should shock an object.
