Homemade Tattoo Machine
Intro: Homemade Tattoo Machine
Steps to create a homemade tattoo machine out of parts found at a local hardware store and in your junk drawer. Enjoy!
STEP 1: What You'll Need
1. USB Fan (Any usb powered product will work)
2. Pen (Krink ink marker)
3. Hose Repair Clamps (2)
4. Spoon or "L" bracket
5. Solder & soldering iron
6. BIC pen
7. Tattoo needle
STEP 2:
Disassemble USB Fan completely.
Separate USB cable, motor and switch.
STEP 3: Grip Body
Take marker, remove back end and empty ink.
Remove cap, cut and place on rear.
Remove BIC pen tube from ink tube and cap, then cut the back end off.
Insert BIC pen tube aligned with center of empty Krink acrylic marker.
STEP 4: Spine Support
Take spoon, remove dish.
Bend handle to create an "L"
STEP 5: Fitting Components
Combine "L" spoon bracket with grip and motor using (2) hose repair clamps.
STEP 6: Wiring Components
Solder switch and USB cord to motor.
Use (1) small hose repair clamp to hold in place.
STEP 7: Needle Set Up
Bend motor drive shaft to offset axis.
Place needle over offset drive shaft and through the pen grip.
Use India ink, ball point pen ink or tattoo ink to tattoo.
For the sake of hygiene, tattoo fruit or synthetic tattoo skin.
STEP 8: (Optional / Not Recommended) Tattoo
Tattoo a frog onto a friend.
7 Comments
Mikki G.W 7 years ago
Tattooing with ball point ink doesn't exactly sound safe... but then again, who knows what actual tattoo ink actually contains..
skintech 1 year ago
brycewong 7 years ago
skintech 1 year ago
Later, Be Safe!
Aerycks 7 years ago
CrazyClever 7 years ago
Very Clever, thanks for sharing!
DIY Hacks and How Tos 7 years ago
Welcome to Instructables. Thanks for sharing with the community. I honestly don't think that I have ever seen a DIY tattoo tutorial on the site before.
