Introduction: Homemade Tofu Italian Meatballs - a Vegetarian Favorite!
Looking for a quick and easy vegetarian option for friends or family? Check out these homemade tofu Italian meatballs! This recipe uses five main ingredients - tofu, egg, croutons, walnuts, and onion, plus seasonings. This recipe makes an average of ~20 meatballs. Enjoy!
Ingredients and Spices:
- 1 package of Azumaya Tofu - Firm
- 1 large egg
- 1/2 cup of chopped onion
- 1/3 cup of crushed croutons
- 1/4 cup of chopped walnuts
- 3 tablespoons of parsley
- 1 teaspoon of Italian seasoning
- Salt
- Pepper
- Extra Virgin Olive Oil
Utensils:
- 1/4 measuring cup
- 1/3 measuring cup
- 1/2 measuring cup
- 1 tablespoon
- 1 teaspoon
- 1 fork
- 1 slotted ladle
- 1 chefs knife
- 1 cutting board
- 1 rolling pin
- 1 deep skillet - 10 inch diameter x 3 inch deep
- 1 handheld oil screen
- 1 small bowl
- 1 large mixing bowl
- 1 weighted bowl
- 1 large plate
- 1 clean towel
- Paper towels
- Set of oven mitts
- 1 stove top with heated burners and oven
- Access to running water and soap via sink
Step 1: Prepare the Tofu
- Remove the tofu from packaging
- Drain off the packaging liquid into the sink
- Wash the tofu with cold water
- Wrap the tofu in a clean towel
- Use a weighted bowl to press the tofu
- Position the weighted bowl in the middle
- Press the tofu for ~30 minutes to remove excess water
Step 2: Prepare the Onion, Walnuts, & Croutons
CAUTION: The knife is sharp and can cause bodily injury
Remember: Before preparing the ingredients, please wash your hands thoroughly
Onion:
- Locate the onion
- Place the cutting board on the kitchen counter
- Using the chefs knife, cut the ends off the onion
- Peel off the onion skin
- Cut the onion into fourths
- For the meatball recipe, use 1/4 of the onion
- Chop 1/4 of the onion into small, diced pieces
- Place the diced onion into the 1/2 measuring cup
- If the 1/2 measuring cup is filled - place the diced onion into the small bowl
- If the 1/2 measuring cup is not filled - repeat the above process - place the ingredient into the small bowl
Walnuts:
- Open walnut container
- Pour a selection of walnuts onto the cutting board
- Using the chefs knife, cut the walnuts into fine pieces
- Pour the cut walnuts into 1/4 measuring cup
- If the 1/4 measuring cup is filled - add the walnuts to the small bowl with the onion
- If the 1/4 measuring cup is not filled - repeat above process - add the ingredient to the small bowl
Croutons:
- Locate a sheet of three paper towels
- Lay the middle section of the paper towels onto the cutting board
- Open the croutons bag
- Pour the croutons onto the middle paper towel
- Cover the croutons with the first and third paper towel
- Locate the rolling pin
- Position the rolling pin over the croutons
- Press down onto the croutons and maintain even pressure
- Roll the rolling pin back and forth over the croutons
- If the croutons are not breaking - smack the rolling pin against the croutons
- Open the paper towel to check if the croutons are becoming a powder
- Pour the crouton powder into 1/3 measuring cup
- If the 1/3 measuring cup is filled - add the crouton powder to the small bowl with onions and walnuts
- If the 1/3 measuring cup is not filled - repeat above process - add the ingredient to the small bowl
Step 3: Prepare the Oil
CAUTION: Oil can become hot and burn the skin
- Locate the deep skillet - 10 inch diameter x 3 inch deep
- Place the skillet on the stove top burner
- Turn on the stove top burner to medium heating (level 4 or 5)
- Open the extra virgin olive oil
- Pour the oil into the skillet to a depth of ~2 inch (enough to cover the meatballs)
- Cover the skillet with a lid
- Let the oil warm for 15-20 minutes
Step 4: Tofu Prep - Mixing Ingredients - Egg
- Remove the pressed tofu from the towel
- Place the tofu into a large mixing bowl
- Locate a metal fork
- Press the fork into the tofu and push downward towards the bowl - breaking up the tofu
- Repeat until the tofu is minced into small pieces
After breaking up the tofu, add the following ingredients to the large mixing bowl:
- Add the walnuts, onions, and croutons
- Add 3 tablespoons of parsley
- Add in 1 teaspoon of Italian seasoning
- Add in a pinch of salt
- Add in a pinch of pepper
After adding the ingredients together, mix well.
- Then, add 1 large egg to the bowl
- Use the fork to thoroughly mix the egg into the other ingredients
Step 5: Prepare Meatballs
Remember: Before preparing the meatballs, please wash your hand thoroughly
- Locate a plate and set it nearby
- Using your clean hands, pick up a small amount of the mixture from the bowl
- Start to form a 1 inch ball
- Press the ball firmly in your hands to compact the ingredients
- Roll it in your palms to make a sphere
- Set the ball aside on the plate
- Repeat the process until the ingredients bowl is empty
Step 6: Cook Meatballs
CAUTION: Oil is hot and can burn the skin
- Take the lid off the heated skillet
- Locate the oil screen
- Hold it in the free hand to limit oil spitting
- Pick up individual meatballs and slowly place them into the hot oil
- Cover the skillet with the oil screen between meatballs
- Repeat until all meatballs are in the oil
Cooking:
- Allow the meatballs to cook for ~10 minutes on one side
- Locate the slotted ladle
- Turn the meatballs to the other side
- Allow the meatballs to cook for another ~10 minutes
Reminder: The meatballs will appear light brown and crispy when fully cooked. If the meatballs are pale colored, cook them for a longer period of time.
Step 7: Remove Meatballs
- Turn off the burner
- Locate a plate and cover it with a paper towel
- Use the slotted ladle to remove the meatballs from the hot oil
- As you remove the meatballs, allow the oil to drain off the ladle into the skillet
- Transfer the meatballs to the plate - the paper towel will absorb the excess oil
- Repeat the process until all meatballs are on the plate
Let the meatballs cool for ~10 minutes. Enjoy!
Step 8: Clean Up
CAUTION: Oil is still hot
- Place a lid onto the skillet containing the hot oil
- Put on oven mitts
- Open the oven door
- Slowly move the skillet into the oven for safety
- Close the oven door
- Allow the oil to cool overnight
- Discard or store the oil for future use
