Introduction: Homemade Web Shooter
In this tutorial, I want to show you how to make a simple web-shooter at home.Now Spider-Man is very popular, so I decided that you would find out how to make it the most popular gadget - web shooter
Step 1: Watch the Video
Step 2: Materials:
- Old watch case
- Aluminum tube 7mm
- Aluminum tube 10mm
- Iron rod threaded at two ends
- Spring - Ring from the keychain
- Nuts
- Plastic cover
- White thread
- Thermoshrinkage
- Iron ball
- Plastic syringe
- Tools
Step 3: Trigger Mechanism
First you need to cut off the tip of the syringe, drill a hole in it for the metal rod and cut the syringe's thread. Then, having increased the diameter of the aluminum tube using heat shrinkage, put our part on it. Metal rod also increase the diameter with heat shrinkage at the end. Then we put a spring on the rod and push it into the aluminum tube. After pushing the other end of the tube through the hole, you need to fix the metal ring on it with nuts.
Step 4: Web
I made a web of white thread at the end of which with the help of heat shrinkage I fixed a metal ball.
Step 5: Installation
I recorded using hot melt on the watch case. Detailed assembly shown in the video.
