Introduction: Homemade Whiteboard/Dry-Erase Board From Scratch! for Doodling and Stuff!
Hello everyone,
So, recently, I thought of buying awhiteboardalso known as a dry-erase boardfor some of the calculations I do for my studies as well as for to-do lists. I searched on the web and ended up looking for dry-erase board stickers made of PVC ( Poly Vinyl-Chloride ) on Amazon.
But I am a hypochondriac and so I started reading about the ill-effects of PVC and looking at them, I started thinking about making one myself. I then started to look for materials lying in my house for making a whiteboard from scratch.
And then....
Here is the list of items I used for completing this build:
- A piece of cardboard for making the board
- Few A4 sized white papers for making the board white
- Clear Cellophane
- A clear cello tape roll
- A pair of scissors
- A paper cutter
- Paper Glue
Step 1: Put Some Glue on It!
⦁ I used the cutter to make the board finer around the corners. You can do it too depending upon your cardboard piece.
⦁ Take some glue.
⦁ Spread it on any one side of the cardboardas shown in the picture above.
Step 2: Stick the Pages/Papers!
⦁ I took 4 papers and then pasted them onto the cardboard to make the board white.
⦁ Then, using some cello tape, I fixated the pages to the cardboard so that they don't fall off.
Step 3: Fixing the 'Dry-Erase' Sheet I.e., the Cellophane
⦁ Take the cellophane sheet and carefully fix it over the board by using cello tape and fixating in a way that the front ( the writing/doodling area ) is almost perfect and with no obstructions.
⦁ My Experience:My cellophane sheet's width was less so, I had to fix another piece which gave it a bit of irregularity. So, make sure that either your board or cellophane sheet is of a measured size. But, sometimes, I guess, it is better to make mistakes :)
Step 4: Final Step, Which Is Testing the Product!
⦁ I took some sketch pens and whiteboard markers to test the whiteboard.
⦁ As you can see in the image attached above, the board works and we can wipe the written/doodled things easily as well.
⦁ NOTE: Permanent markers don't work. Make sure you use sketch pens or whiteboard/dry-erase markers specifically made for such purpose.
⦁ TIP: Don't smudge/wipe the board with your hands as the chemicals in the markers may have affects on you. Also, use either a microfibre cloth or a cotton cloth to wipe off your writings/doodles.
Lastly, take care of the board and make your students/children or yourself work on this whiteboard and experience the magic of Do-It-Yourself products!
I hope you all liked this Instructable. Thanks for reading till the end.
Take Care of Yourself and Everyone else!
Stay Healthy! Stay Creative!
Thanks for Stopping By! Hope you have a great time!
